Old 02-11-2024, 04:16 PM   #1
2018 33' Classic
Thousand Oaks , CA
Access Panels
AS cut access holes for access to fresh water drain, plumbing issues etc. They replaced with flat sheet metal using screws.
These panels allow moisture into the bottom of these areas. Has anyone replace with a more secure panel?
candrews768 is offline   Reply With Quote
Old 02-11-2024, 10:27 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
To my knowledge belly pans are not water tight. There isn't really a need to waterproof them in my opinion.
Richard
11018
richard5933 is offline   Reply With Quote
Old 02-12-2024, 07:06 AM   #3
Oak Park , Illinois
+1
If it makes you sleep better, you could unscrew the panel, add some caulk and button it back up, but that won't seal the many areas of the belly pan that are not watertight. I have a similar patch on my tank cover.
If you lift the trailer or lower it via the hitch jack and you don't see water pouring out from the pan, I'd not loose any sleep over it.
sfranklin is offline   Reply With Quote
Old 02-12-2024, 08:18 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
X2
Hey Candrews,
If you really want to install something easier to open and watertight for access, some of us have used deck plates. Check these posts. https://www.airforums.com/forums/f36...ml#post1277620
https://www.airforums.com/forums/f39...ml#post1271272
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 02-12-2024, 09:53 AM   #5
1988 32' Excella
Robbinsville , New Jersey
Frankly that access panel is more likely to let moisture out then in, in most cases water likes to go downhill.
Old 02-12-2024, 11:54 PM   #6
2018 33' Classic
Thousand Oaks , CA
The issue is I can see from inside the trailer to where the access panel is. So I guess I am going to use insulation and flex seal.
Old 02-13-2024, 08:43 AM   #7
1994 25' Excella
I wouldn't recommend doing anything which will make it difficult or impossible to get into in the future. If there was need to enter that area once, there likely will be again in the future.
If you're intent on sealing it just get some adhesive foam weatherstripping and put it between the two layers.
Just because you can see from inside the trailer to where the access panel is doesn't mean anything, and there's little to no chance of water getting inside the trailer through that access panel, waterproofed or not.
Our trailers are not hermetically sealed underneath, and they're not intended to be.
Richard
11018
Access Doors/Panels VeloBuckeye Airstream Lifestyle 0 06-10-2019 05:26 PM
Airstream 2016 FC Access panels jamieb1086 Airstream Classifieds 0 07-17-2018 02:19 PM
Thetford C200 and other access panels ericpeltier Sinks, Showers & Toilets 1 09-28-2015 12:23 PM
Missing keys on access panels kaulike Doors & Locks 5 09-17-2006 12:10 AM
