08-13-2021, 08:15 PM
1973 23' Safari
Germantown
, Tennessee
70's battery box/door question
The photos show my battery box ('73 Safari) taken out of the Airstream.
The "under" shot shows that someone added a plate to attach the hinge to. This seems to put the hinge farther away from the box a bit. I thought at first there must have been damage under that plate and it was a repair, but you can see from the "inside" shot that that is not the case. That metal plate seems to only be there to move the hinge away from the body, unless I'm missing something.
My question is: am I correct in thinking the hinge should be flush with the original floor of the box?
You can see in the picture a few steps back that the door is not aligned well with the camper. Now, I'm repairing rust and wood back there, so a little of that is because the battery box was not supported well. I wonder if moving the hinge was someone's way of "fixing" this.
08-14-2021, 04:15 AM
1994 25' Excella
Waukesha
, Wisconsin
Just a guess here, but with all those extra holes and dead rivets, it looks like the hinge was replaced at some time in the past. Perhaps the original hinge was a single-sided offset hinge and not a flat one, something like this: https://www.amazon.com/ABS-Stainless.../dp/B07H5M5G56
Richard
11018
08-14-2021, 05:46 AM
1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
Looks like they added plate on bottom but riveted it from top leaving rivets in the way where hinge attaches. Original hinge probably had broken rivets and holes left were too large to hold a rivet, hence the plate which was not properly positioned.
08-14-2021, 05:48 AM
1984 27' Airstream 270
West Chester
, Ohio
Looks like it was moved away at the bottom possibly to allow drainage of water intrusion related to the failed seal. It looks cracked and broken which would allow rain water right into that compartment (including access to the sub floor edge)
Maybe replace that seal and see how close you can get to water tight, at least making a drip rail along the top of that compartment opening
08-14-2021, 07:19 AM
1973 23' Safari
Germantown
, Tennessee
Found a good pic of a '72
Unless they changed it for '73, it does look like the hinge was a different shape.
Edit: I'm less sure looking at it again; I think I am seeing the bottom "lip" that holds the black plastic piece in place on the hinge end of the door.
08-14-2021, 07:34 AM
1973 23' Safari
Germantown
, Tennessee
Here's one that shows a bent hinge on the trailer side of the hinge.
08-14-2021, 08:35 AM
1973 23' Safari
Arroyo Grande
Greetings, I would agree that the hinge was previously replaced at some point in time but what is a bit odd is that our ‘73 Safari also had that same patch piece nearly identical to yours. Ours also had quite a bit of corrosion that appeared to be from battery boil over and we thought that may have initiated the problem.
08-14-2021, 10:33 AM
1973 23' Safari
Germantown
, Tennessee
That is interesting! The "pan" on mine doesn't seem corroded and does seem to be original (there are factory rivets holding it in). The hinge was replace, I'm sure, and I have a new hinge (standard flat hinge) that I'm going to install, but before I do, I want to know if it should be flush with the end of the original pan.
Thanks again
08-16-2021, 08:40 AM
1973 23' Safari
Arroyo Grande
We had to replace the rear section of subfloor which required removing the battery box. When we reinstalled, we started by aligning the door assembly both gap and rub rail and then the hinge was reattached underneath. Best to replace the seal first as this also affects door location. Not sure if this answers your question?
Steve
08-16-2021, 10:13 PM
1973 23' Safari
Germantown
, Tennessee
Steve
Thanks Steve! I think that's how I will proceed.
I am replacing that bottom sheet metal that looks like Swiss cheese. I may double it up for more strength.
08-22-2021, 07:18 AM
1973 23' Safari
Germantown
, Tennessee
Made a new "floor" for the compartment out of diamond plate aluminum.
08-23-2021, 07:34 AM
1973 23' Safari
Arroyo Grande
The Diamond plate will be a nice addition. Just curious, are you still using the original plastic battery box liner as well?
08-23-2021, 01:34 PM
1973 23' Safari
Germantown
, Tennessee
Yes, I'm making repairs to the damaged ABS plastic. It was in pretty rough shape. I'm using a slurry of acetone and black ABS sheets I bought on Amazon.
09-01-2021, 11:32 AM
1973 23' Safari
Germantown
, Tennessee
Here's shot under the battery area before I took it all apart. Is the bottom of the battery compartment supposed to be open like this, i.e., not covered by the belly pan?
09-02-2021, 08:52 AM
1973 23' Safari
Arroyo Grande
On our Safari, the rear banana wrap is at the same level as the bottom of the battery box which would be even with the weld line on the welded section at the back. I tried to attach a couple of pics, see if it works, a first for me.
Steve
09-03-2021, 05:33 AM
1973 23' Safari
Germantown
, Tennessee
Thanks, Steve!
It's a little hard to see in the pic, but is the belly pan section one continuous section back there? Like it covers the bottom of the battery box so you can't see it?
09-03-2021, 08:42 PM
1973 23' Safari
Arroyo Grande
On ours, the piece of aluminum attached to the banana wrap covers the battery box. There is one small piece if the belly pan that fits over the battery box that coincides with the jack point. I’ve attached a couple of more pics. Hope this helps
Steve
09-04-2021, 05:45 AM
1973 23' Safari
Germantown
, Tennessee
Perfect! Thanks! That looks so much better. Will have to rework mine when I put the wraps back in.
09-04-2021, 06:02 AM
1994 25' Excella
Waukesha
, Wisconsin
Shouldn't the vents on the battery box be open to the outside? If your banana skin covers the vent, how are battery gasses being vented?
Richard
11018
09-04-2021, 08:36 PM
1973 23' Safari
Germantown
, Tennessee
Vents? Do you have a pic? Thanks
