Old 09-05-2021, 06:16 AM   #21
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Originally Posted by lojoma View Post
Vents? Do you have a pic? Thanks
I assumed that's what we were seeing in posts #14 & 15.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 09-05-2021, 07:29 AM   #22
1973 23' Safari
Central Coast , California
Good question on the venting. Airstream did refer to this as a vented box and on ours, best we could tell, there are some holes on the sides for cables that are covered by the banana wrap which does not have an airtight fit outboard of the frame. Also, the seal is only on the top so the hinge area can vent air as well.
StevenD is offline   Reply With Quote
Old 09-05-2021, 07:49 AM   #23
1973 23' Safari
Old 09-05-2021, 09:25 PM   #24
1973 23' Safari
Germantown , Tennessee
Do you mean the round opening aft of the battery box? That's for the bath fan outlet. Maybe I'm not getting what you mean.
lojoma is offline   Reply With Quote
Old 09-05-2021, 09:26 PM   #25
1973 23' Safari
Steve, how far around is the door seal supposed to go?
Old 09-06-2021, 08:29 AM   #26
1973 23' Safari
Another good question. I had forgotten that I left a space at the top without the seal. Iím sure I duplicated the original installation so this would aid in venting. Otherwise, the seal extends around the opening on both sides down to the hinge. Hereís a pic.
Steve
Old 09-06-2021, 06:26 PM   #27
1973 23' Safari
Thanks Steve!
I had seen other pictures with the seal missing at the very top and I wondered why that was.
Iím jealous of how original and in good shape your Safari is.
If I can bother you for another pic, can you take a photo under the camper above the steps? I would like to know if there is visible plywood there. I am taking apart that area and from top down I have 3/4Ē plywood, then aluminum, then some 1/4Ē plywood touching the step outrigger tops. But it is cut away so it doesnít go across the whole opening above the stepsÖ.just on top of the outriggers. I have seen a pic of a Safari with visible plywood there. Just would like to know that itís supposed to be. Thanks!
Old 09-07-2021, 08:24 AM   #28
1973 23' Safari
Here are a couple of pics under the step area. I donít see any exposed plywood under the trailer.
Thanks for your comment. We are nearly finished with a 5 year refurbishment/restoration of our Safari and are preparing for our first outing later this month.
Steve
ID:	403584   Click image for larger version
Old 09-07-2021, 12:31 PM   #29
1973 23' Safari
Thanks, Steve! I guess the luan was just filler over the outrigger.
Old 09-21-2021, 11:02 AM   #30
1973 23' Safari
Trouble with Nutserts
New problem. I am trying to replace the Nutserts that hold the bolds for the door cables (the ones that keep the door from opening too far).
My problem is hopefully shown in the photos. The Nutsert is installed by basically squeezing it to compress it a bit, so it tightens in the hole and won't come back out.
My issue is where the "bend" takes place as it's compressed. The thickness of the plastic housing and the metal inner support pieces are too thick for the nutsert to work. The "bend" is inside the plastic rather than out of the inner side of the metal "wall".
If anyone has replaced these and has tips, I would appreciate it.
ID:	404538   Click image for larger version
Old 09-24-2021, 08:00 AM   #31
1973 23' Safari
I think I found some Nutserts that are made for thicker walls. I have them on order. We shall see.
Old 09-24-2021, 10:25 PM   #32
1973 23' Safari
Success! You can see in the photo that the new rivet nut is longer and has a longer crimp area.
For future reference:
https://www.fastenal.com/product/fas...FamilyId=33434
SKU 0125638
ID:	404803   Click image for larger version
Old 11-07-2021, 09:43 PM   #33
1973 23' Safari
I finally got to work under the camper in the battery area. I think this looks much nicer than what I had to work with!
Old 11-20-2021, 01:26 AM   #34
sondo007's Avatar
1972 31' Sovereign
saint louis , Missouri
Question: What are dimensions of the interior of the battery box when the door is closed? I want to put in a slide rail so the battery can slide out, but after seeing this, I realize I don't think I can do that if the door closes it will shortened the space I need for the rail system which is 14.24. thanks
sondo007 is offline   Reply With Quote
Old 11-22-2021, 09:00 AM   #35
1973 23' Safari
I don't have the dimensions handy but it is going to be barely deep enough for the battery to sit snugly in there, so I think your measurement will be too much.
Old 01-02-2022, 10:22 AM   #36
1973 23' Safari
Finally have finished the battery compartment. That door was a PAIN to get reinstalled. Photo shows happy battery sitting in there, all buckled in.
AS Maintaining Battery Box and Battery Terminals sooners95 Electrical - Systems, Generators, Batteries & Solar 0 04-16-2020 11:35 AM
DC Bus Bar Box - Question - Loose bar free in box JennyJakeNH Electrical - Systems, Generators, Batteries & Solar 1 07-16-2019 05:37 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 11:01 AM
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
