Old 05-08-2021, 07:29 AM   #1
1957 22' Flying Cloud
Rosendale , New York
Wheels for 1957 Airstream
Looking to replace 15 inch five on 5 1/2 lug rims for whatever works on my Airstream desperately seeking help PJW 315@verizon.net
Sandydog1 is offline   Reply With Quote
Old 05-08-2021, 08:30 AM   #2
1966 22' Safari
Fredericksburg , Texas
ST 225 75R15 Goodyear Endurance is what we have on both our trailers. The last set I bought I told the guy I wanted the most recent set manufactured and he accommodated. Good luck
Bubba L is offline   Reply With Quote
Old 05-08-2021, 08:48 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Here's a list of vehicles that used the 5X5.5 bolt pattern if your looking for used wheels.
https://www.roadkillcustoms.com/whee...5x5.50-inches/
If you want new just google "15" wheels with 5X5.5 bolt pattern"
Make sure you match for stud size and back spacing.
I assume your getting rid of the split rims it came with.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 05-08-2021, 12:26 PM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
1957 will be a fun trailer
Hi There,
In addition to 5.5x5 boltcircle, you want to indicate center-hole diameter, rim width, rim diameter, and offset from centerline. You can calculate your offset by measuring your existing wheel’s rim width and backspace dimension if they are original to the trailer. Most common trailer offset is “zero”, not so for most automobile wheels. It's possible that stud/lugnut diameter will play too and that'll be 7/16 or 1/2 inch.
Trailer wheels are usually rated for heavier loads than car wheels, so that might matter to you.
You’ll also want to know if you require “hub-centric” or “lug-centric” wheels.
And…. decide how your hubcap attaches, with vintage "clips" style or the newer "nubs" style. These hubcap mounting methods are not interchangeable. Some wheels have no provision for baby moon caps and only accept full wheel covers. I'd guess "clips" is period correct to 1957.
The world wide web will explain all this measuring in detail
Best
ALUMINUMINUM is offline   Reply With Quote
Old 05-10-2021, 02:25 PM   #5
2004 30' Classic Slideout
Sun Lakes , Arizona
Set of 15” Rims
I have a set of Alcoa Aluminum 15” rims from my 2004 30’ Classic. If interested let me know
ken.bauman is offline   Reply With Quote
Old 05-10-2021, 11:20 PM   #6
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
ken.bauman: Contact Kevin At Airstream Service. Airstream bought mine as they need them to replace an occasional damaged wheel. New wheels are no longer available. When I went to 16" Michelins they asked me for them.
guskmg
Old 05-11-2021, 04:59 AM   #7
NO HUMBLE OPINION
QUOTE.... "Looking to replace 15 inch five on 5 1/2 lug rims"
The OP is asking for an uncommon size wheel for his airstream. We don't know if he has an uncommon axle or modification to his 1957 trailer.
The only airstream five lug wheels I'm aware of were mid sixties on small trailers like Caravel.
The typical airstream six lug wheel that most all of us have on our airstreams is not what he asked for.
If he doesn't want restoration quality original looking, period correct airstream wheels, he can buy white spoke five lug 15" zero offset lug-centric doofus wheels about anywhere including tractor supply and walmart.
Old 05-11-2021, 08:07 AM   #8
NO HUMBLE OPINION
The OP has a concurrently running post asking help to replace his split-rims. And again, five-bolt.
https://www.airforums.com/forums/f48...es-222564.html
Maybe 1957 bolt circle pre-dates the most common vintage steel six lug “chevy truck wheel”. Any historians to clarify?
Late sixties airstream brochures tout their “Heavy Duty Truck Wheels" in their advertisement. I have a 1968 Chevy K10 Suburban with its original wheels that are absolutely identical to my airstream 15” six-lugs in every measurement, including zero offset, weight, and weld pattern. Neither say Kelsey-Hayes, but that’s what they are known to be.
If OP is desperate, maybe switch or drill drums to the most common six lugbolt pattern. Then have options from junkyards to Centerline Auto-Drags.
The OP hasn’t responded in a few days to either of his posts, so perhaps he is no longer desperate??
Pretty cool that the rivet spacing on Centerline Auto-Drags matches vintage airstream shell.
Pictured first is a six lug airstream wheel from the sixties that has "clips" to hold the somewhat rare and expensive today, older style ribbed edge baby moon hubcap.
The second image, mounted on 68 trailer is a seventies airstream steel wheel with "nubs" holding a jc whitney baby moon (so old, it's labeled "Made in Japan"). It appears that airstream never offered a moon cap for this later "nub" style wheel, It had a "full" wheel cover.
ID:	395271   Click image for larger version
Old 05-11-2021, 09:43 AM   #9
NO HUMBLE OPINION
More airstream wheel stuff
ID:	395277   Click image for larger version
Name:	1970 hubcapAS.jpg
ID:	395279   Click image for larger version
ID:	395281   Click image for larger version
ID:	395283   Click image for larger version
Aluminum Airstream Trailer Wheels 15Â*» wheels 6 Lug ArielAirstrm Airstream Classifieds 0 12-22-2019 12:46 PM
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
