RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-26-2020, 10:44 PM   #1
2021 25' Flying Cloud
Woodbury , CT
Weight Distribution
I have a question about front axel weight.
My truck has a front axel weight of 3200lbs, back axel of 2500# with just me and a full tank of gas.
When I add my 25' flying cloud, the front is now 3000# and the back 3540#. tongue weight is 837. Which all makes sense when you add it up.
My question is, after adding the trailer, should I attempt to get my front axel and the rear axel be similar in weight? and is the front axel suppose to loose weight after adding the trailer? Everything appears to be level.
I am using an Andersen no sway weight distribution hitch.
Thanks in advance for any insights!
stevegilmore is offline   Reply With Quote
Old 10-27-2020, 06:52 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
The "big truck" boyz will say leave it alone.😂
Disclaimer...I'm not a BTB...and not a fan of anything Andersen.
I doubt 200lb off the front axle will be a noticeable concern.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 10-27-2020, 07:28 AM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
The main point of WD is to maintain an even distribution of weight across the 3 sets of wheels. Adding weight to the back naturally lifts the front up, as you have measured.
IMHO, WD makes the driving safer. I would hate to be going down the road and then find out my steering control has been lost or out of control
my 2 cents
waninae39 is online now   Reply With Quote
Old 10-27-2020, 08:05 AM   #4
2018 27' Globetrotter
Elbert , CO
Are your "after" weights taken with the WD hitched up? If your rear axle has absorbed all of the tongue weight AND 200 lbs from the front axle, it does not seem to me that your WD is doing anything at all. The results you are reporting are what I would expect to see if you were towing on a simple ball.
djb75 is offline   Reply With Quote
Old 10-27-2020, 08:43 AM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Shoot for 50/50.
wulfraat is offline   Reply With Quote
Old 10-27-2020, 10:34 AM   #6
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Is the WD engaged and is the trailer level? If so, you're probably okay.
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
"Weight Carrying" vs "Weight Distribution" PasoArt Towing, Tow Vehicles & Hitches 2 01-11-2016 09:04 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 11:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 01:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 09:13 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 03:48 PM
