Old 06-06-2018, 10:57 AM   #1
1975 31' Sovereign
El Dorado , California
Wally Bynum numbers
Hello,
I have 2 older Airstreams that have numbers on them designating memberdhip in the Wally Bynum Club. How fo I get replacement numbers? The original were blue.
Thank you
keypunch1 is offline   Reply With Quote
Old 06-06-2018, 11:05 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
for WBCCI - Wally Byam Caravan Club International
https://wbcci.org/
^^Start here^^
If the numbers are blue, that might indicate membership in The Airstream Club (TAC).
http://www.airforums.com/forums/club.../list-by-name/
^^ find a local group here^^
Alan
Old 06-06-2018, 11:22 AM   #3
1975 31' Sovereign
Thanks for information. When I called the club in order to get replacement numbers you have to be a member.
Any ideas to paint over or another place to purchase them?
Old 06-06-2018, 11:39 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I am a little confused. You want to have Wally Byam numbers on your trailer, but you don't want to be a member of the club that the numbers represent? Why not join the club and display your numbers?
BTW, my first job at IBM was servicing keypunch machines. Nice user name...
Richard
Old 06-06-2018, 12:02 PM   #5
2007 22' International CCD
The numbers are usually a vinyl adhesive product.
They can be removed without damage using plastic single edge razor blades to lift and peel the vinyl and "Rapid Remover" spray and paper towels to remove the adhesive residue.
Both items easily available on Amazon...
The numbers are assigned by the club to current members, and should only be displayed by legitimate current members...If you want to display numbers, please join the club.
Those (expletive deleted) Wally Bynum Numerals bvcg1 Exterior Restoration Forum 24 11-20-2015 08:08 PM
Serial and Wally Byam numbers TDOW 1966 - 1968 Safari 0 09-18-2014 09:00 PM
Wally Byam Numbers msieber109 Airstream History 4 03-05-2009 08:57 PM
Removing Wally Byam Numbers? Marcia Cleaning, Stripping & Polishing 6 02-16-2006 08:19 AM
