Old 08-28-2019, 06:04 PM   #1
Bellaire , Texas
useable amp hours
I have recently installed 2 trojan t-105 batteries. Battery rated at 225 amp hour. Will my useable hours be 110 amp hours or 225 amp hours? Thanks!!!!!!
Bigeddie58 is offline   Reply With Quote
Old 08-28-2019, 06:19 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
110AH or 50% of your total AH
Two 6 volts wired in series increases voltage to 12 volts but AH stay the same.
Two 12 volts wired in parallel increases AH but voltage stays the same.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Dept of “Overkill”
Old 08-28-2019, 08:00 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The usable will be 110, as he said. Minus the amount you lack in getting them fully charged each time. If running a generator or solar that could be a good bit.
Remove Microwave For Other Useable Space Or To Reduce Trailer Weight ? jcole 2005 and newer - Bambi all models 28 05-03-2020 09:14 PM
16' to 22' Airstream in useable condition slwshanners Airstream Classifieds 0 01-23-2015 07:14 AM
low voltage cutoff vs AMP hours used at high amp draw morgandc Batteries, Univolts, Converters & Inverters 0 11-02-2014 09:38 PM
'05 Safari: More amp-hours in stock battery box tpi Batteries, Univolts, Converters & Inverters 15 09-17-2007 11:39 AM
22 Hours & 1200 Miles/ WE MADE IT!!! blucloud 1984 - 1989 Sovereign 1 01-29-2006 06:31 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
