Old 05-05-2021, 08:02 AM   #1
2002 22' International CCD
1989 32.5' Airstream 325
Sherborn , Massachusetts
Tiny home or road worthy
Long time reader finally new owner..
So I managed to get my paws on a 2002 International CCD. Had known frame issues that had been repaired.. and also the previous owner has “replaced” the floors aka didn’t know anything about subfloors. 🤦🏻*♂️
I pulled her from NM back to the east coast where I will work on her this summer. But potholes on the way and bad tarmac seems to have made her sag from 2 inches curbside to now 4! And the “floor” inside has buckled a bit.
My question is how dangerous road worthy is it at this point to go a 100 more miles.
At this point with the outrigger bend do I have to do a full frame off fix?
I’m decent handy but I don’t have a gantry so was thinking fix floors the hard way (shell on) and fix her totally when I want to use her to really travel.
And yes I bought from a friend of friend.
But in 4 days of research have realized most. Everything that you should not/never do with a 2002 international.. he did.
Thank you in advance!!
ID:	394916   Click image for larger version
ID:	394918   Click image for larger version
CameraJ is offline   Reply With Quote
Old 05-05-2021, 09:13 AM   #2
Long Island , New York
Welcome to the forum!
In my personal opinion . . .
Roadworthy? -- unknown and risky to try, but on a very smooth roadway with no hard turns or strong cross-winds . . . you might pull it off IMO.
Full frame-off fix? -- probably yes IMO.
Just guesses IMO . . . based on incomplete data FWIW.
Good luck,
Let the music lift you up . . .
Old 05-05-2021, 09:20 AM   #3
2020 23' Flying Cloud
Sebastian , Florida
It sounds like you know what needs to be done, but the lack of a gantry is stopping you. The extensive work you describe would best be done under a shelter. Can you invest in a shelter sturdy enough to accommodate a gantry, that would then serve as your trailer’s home?
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 05-05-2021, 09:37 AM   #4
PS -- "The Love Shack" thread is a good full-frame shell-off read IMO:
https://www.airforums.com/forums/f22...ck-183431.html
Happy trails,
Name:	Love Shack grass 5 May 2021.png
Old 05-06-2021, 01:42 PM   #5
Oof part deux
Wow the full on thread for your argosy amazing..
So now with full sunlight managed to put the 22 into a spot where I planned to work on her. Of course didn’t remove fully the anti sway 🤦🏻*♂️
But attached photos of her with the full list to the curbside. I think the PO didn’t realize how bad it was since roads in the SW are so damn smooth. A few bumps on 95 and the floors have literally started coming up..
So possible to do a light patch that allows to drive her 2 hours to a campsite for the summer than tackle the foundation in the fall.. she won’t move. I can jack and support her and put down wood and carpet and use as a tiny home..
Or.. is she destined to sit till totally redone. Seems my touch is was beyond my grasp.
Anyone know any airstream techs/shops in Boston area? I found one way out in Deerfield but definitely not taking her to anyone but experienced..
Thanks in advance.
ID:	395001   Click image for larger version
Old 05-06-2021, 01:52 PM   #6
Personally, the only way I would move her is to hire a towing/moving firm, and put your trailer on a low-boy trailer etc..
And yes you need to support the frame ASAP, and also during any moving operation IMO.
Good luck,
Old 05-07-2021, 09:36 AM   #7
Agreed
Otra yes it’s seems that way.
Sadly 17 hours it was “ok” but the roads in New England, those last 20 minutes off highway..
‘‘Twas the straw that broke the back.”
Thanks for the input!
Old 05-09-2021, 08:52 AM   #8
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I'm not sure that a shell-on floor replacement is harder than shell-off. I replaced the floor in my '74 Sovereign with the shell on. I can see that there are definite advantages to having the shell off and being able to flip the frame over, but there are also advantages to doing it with the shell on. I didn't have to get gantries, I didn't have to remove and reinstall the shell, and I didn't have to worry about damage to the shell in the process, or while it was being stored. With the shell on I was still able to do all the welding and painting and replace the floor, and since I was working outside, leaving the shell on meant I could still work on rainy days.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Camper vs tiny home stormbornSG Full-Timing 11 10-05-2016 03:24 PM
Getting 1961 Safari road worthy Airwave503 Wheels, Hubs & Bearings 1 07-22-2014 04:53 PM
Is it road worthy. dennydwk Winterizing, Storage, Carports & Covers 4 03-03-2014 09:41 AM
Help with road worthy check before towing Cleveland OH to Austin TX vesperaustin General Repair Forum 7 11-21-2012 11:29 PM
TINY, TINY parts repair JBK General Repair Forum 6 06-16-2006 03:19 PM
