Old 12-08-2015, 09:52 PM   #1
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
"Snap Hangers by Airstream"
Anybody ever seen these? Snap on hangers, apparently an exclusive item to the Wally Byam catalog back in the 1960s.
They're so clever ~ it's a simple wire hanger with an extra nub that lets you snap them onto the bar so they can't hop off on bumpy roads. We own a half dozen, which came with our '62 GlobeTrotter... but would love to find another dozen or so. I've found no references to them online, so far.
bredlo is offline   Reply With Quote
Old 12-08-2015, 10:17 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I have some plastic hangers that snap securely onto a clothes rod, but not metal ones, and they're certainly not Airstream originals. But if all you want is hangers that won't jump off the clothes rod, these will do…
http://www.amazon.com/Slip-Light-wei...TE6STVJ2R4TJQ0
Old 12-09-2015, 05:28 AM   #3
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
I have another variety of plastic RV hangar I found on eBay. Don't remember the brand, and the trailer is in storage so no pics available. They work great.
mimiandrews is offline   Reply With Quote
Old 12-09-2015, 05:36 AM   #4
Lily&Me's Avatar
Normal , Illinois
Y'all are not carrying enough clothes if the hangers jump off the rod in travel.
I have never had that problem.
My Interstate has a sort of double rod that pulls out, and is narrow enough top to bottom that hangers coming off in normal travel would be nearly impossible.
Maggie
Lily&Me is offline   Reply With Quote
Old 12-09-2015, 07:32 AM   #5
bredlo's Avatar
1954 22' Safari
Thx for the modern suggestions, they certainly seem to be functionally equivalent.
Old 12-09-2015, 07:43 AM   #6
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Haines , Oregon
Is this a problem? I don't recall ever having a hanger come off the closet rod.
Drathaar is offline   Reply With Quote
Old 12-09-2015, 07:51 AM   #7
Images: 59
Hanger jumping off is a result of unbalanced running gear and over-hitching.
Old 12-09-2015, 07:54 AM   #8
Or the result of really bad Louisiana highways, where the only way to dodge the potholes is to hit the bumps, and vice versa.
Old 12-09-2015, 08:25 AM   #9
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
Mine,
http://www.amazon.com/Tri-Lynx-1200W...rds=rv+hangers
MICHAEL
Old 12-09-2015, 10:25 AM   #10
bredlo's Avatar
1954 22' Safari
No, probably not a problem for most.
They just have a nice slim profile, they're made from thick wire, and the added function of being able to push them onto the rod is cool, and theoretically allows you to mount the rod closer to the ceiling because you're not living the hanger over and down onto the rod.
They're just a neat trailer accessory that serves as another reminder that you're on the road, and not in a house.
Old 12-09-2015, 12:23 PM   #11
2011 30' Flying Cloud
Greenback , Tennessee
Protagonist, what is your experience with these hangers? Is there a trick to getting the things off the rod? The reviewers didn't like them, but no-one mentioned using them in an RV. The price is certainly right, if I can use some of them at home.
Richard
Gneiss Guy is offline   Reply With Quote
Old 12-09-2015, 12:41 PM   #12
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I have those that AWChief mentioned. . . work great. . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 12-09-2015, 01:17 PM   #13
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
The undulations of Louisiana asphalt were our first (& only) experience with flying hangers. My solution for this recurring route was two small D-rings mounted at the rod ends and a hooked bungee cord stretched between the rings. Certainly cheap, highly successful, and bungee removal at the campsite allows easy use of any hanger type.
SeeMore is offline   Reply With Quote
Old 12-09-2015, 01:56 PM   #14
1970 23' Safari
Torrance , California
"found" solution
Several years ago in someones trash (yes, I have been known to "dumpster dive" I found a bunch of old hotel hangars. They have a metal ring that clips over the pole with a tab/slot hanging down. The hangars themselves are nice heavy wood (must have been a "good" hotel) with a metal pin with a large head that hooks into the bracket.
The hangars do not jump off of the rod but they lift off easily when you need to remove them.
I know this is not what you were looking for but I thought I would add my solution/ 2 cents worth.
1970 Safari is offline   Reply With Quote
Old 12-09-2015, 03:27 PM   #15
Pretty simple them on or off the rod. Just press the spring clip far enough in, and it will slip off like a regular hanger.
But I'll probably switch to the ones AWCHIEF uses, because they're even simpler.
Old 12-09-2015, 08:43 PM   #16
bredlo's Avatar
1954 22' Safari
Originally Posted by 1970 Safari View Post
Several years ago [snip] I found a bunch of old hotel hangars...
I know these well ~ they're another great design, I agree. My only complaint about those is the bit of concentration it requires to get the little ball in the slot, wheres these Airstream hangers can be operated practically without looking.
Thanks for the idea though!
Old 12-12-2015, 03:13 PM   #17
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
Hangers that jump off? Nope.
3wd67rg is offline   Reply With Quote
Old 12-12-2015, 03:55 PM   #18
1976 31' Sovereign
Oswego , Illinois
I Pur. a dozen or more airstream hangers when they first came out, they are great and no I will not part with any of them. We also use some heavy plastic hangers if not enough airstream hangers for every thing.
featherbedder is offline   Reply With Quote
Old 12-12-2015, 08:16 PM   #19
bredlo's Avatar
1954 22' Safari
Wow! You're referring to the 60s metal ones I pictured in the first post?
That's nifty. Whether or not hangers fall off, I love these things. They're a beautiful little design.
Perhaps I'll reproduce them, since it seems so few people have seen them.
Old 12-12-2015, 09:47 PM   #20
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, not necessarily. I don't have either of those problems, but I can't stop bumps in the road. Looking for new coat hangers.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline   Reply With Quote
Clothes hangers that don't fall off amathis55 General Interior Topics 37 04-13-2008 07:53 AM
Drapery hangers Lumatic Upholstery, Blinds, Walls & Interior Finishes 5 05-06-2007 03:20 PM
Holiday light hangers- 2006 Classic thecatsandi 2006 - 2010 Classic (all lengths) 9 11-24-2006 10:30 AM
Huggable Hangers (HSN Shopping) Foiled Again Off Topic Forum 4 02-08-2005 09:30 PM
