Old 03-29-2019, 07:09 PM   #1
2016 27' International
Anacortes , Washington
Simple solution for bath mirror “headache”
Like others looking for a solution to the overhead bath mirror not being restrained in the up position, I came up with an idea after trying the more intricate gas strut option, and finding it too involved. I didn’t want “mistake screw holes” seen from trying to find the successful location for both strut ends. Too much geometry with this cabinet.
So, I bought a 3” long Surface Bolt, Ace #5429816, satin nickel, $9. The gap between side wall and edge of mirror is about ˝”-⅝”, wider than the surface bolt is thick, so I needed a spacer between the side wall and surface bolt to securly catch more of the mirror. I had a piece of 1”x1/4” aluminum bar, and I cut it to 3” long, and drilled it to match the surface bolt holes. I wanted a little more of a spacer, so I added a split lock washer (because it is thicker than a normal washer) between the alum bar piece and surface bolt, using the screws. Then just decide where on the side wall you want to mount it. Tighten the two screws, and done - lift mirror left hand, slide bolt right hand.
ID:	336881   Click image for larger version
Pat Pierce is offline   Reply With Quote
Old 03-29-2019, 08:08 PM   #2
2009 30' Classic
a city in west GA , Georgia
Wow thanks
A project I will do.I need to secure mine up so I can use it.
Joyman is offline   Reply With Quote
Old 03-29-2019, 09:27 PM   #3
2007 22' International CCD
Clever and simple!
Extending Kitchen Counter Space 19' 2007 Bambi SE / Simple Solution pkm123 2005 and newer - Bambi all models 2 09-10-2024 06:46 PM
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 03:23 PM
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 03:14 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
the headache of cleaning old caulking nevisstudio Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-29-2004 03:12 PM
