Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 08-02-2022, 07:40 AM   #1
2019 25' International
Atlanta , Georgia
"Shout out" to Southland RV in Atlanta
Just a quick note to say thank you to Southland RV for finding the mysterious water leak that had been bugging me for several months. The leak was discovered at the low point fresh water drain. Inside the belly pan there is a short piece of PVC pipe that connects the tank with drain valve. A hair line crack was discovered and the pipe was replaced. Since then, no leaks. Thank you.
1590Denny is offline   Reply With Quote
Old 08-02-2022, 08:42 AM   #2
Boxite's Avatar
2008 22' Safari
The cheap plastic drain valve designs of these expensive Airstreams is shameful.
One of the FIRST THINGS I DID was to drill out the rivets on the sheet-metal box that contains the fresh water tank… remove that cheap plastic valve which Airstream has EXPOSED to everything that passes under the trailer…. and replaced it with a brass ball-valve from Home Depot connected to the tank with clear poly tubing. Never had a problem.
Old 08-08-2022, 12:01 PM   #3
Atlanta , Georgia
The brass ball valve mounts below the tank. What did you do to protect the valve from debris from the road?
Southland Airstream, Georgia Tashtego Buyer Guidelines 3 06-11-2022 06:02 AM
Southland RV in Norcross, GA Belbein Airstream Trailer Forums 16 06-25-2021 06:40 PM
A shout out jcanavera Member Introductions 0 08-08-2012 01:32 PM
A Shout Out.. a walk in the woods.. DanielB Off Topic Forum 1 07-14-2011 07:15 PM
