Old 03-26-2020, 12:56 PM   #1
2018 25' International
Lewisville , Texas
Sewer Dumping (Plumbers help)
I'm not sure where to post this but here goes. For those times I'd like to dump at my home, I'd like to use the 4" sewer line connection. The problem is, I have three of them.
One by the street and two up by the front of the house within 2 feet of each other.
Which one should I use?
Also, it isn't illegal to do this in my community.
Matt & Roxanne
2018 FB Twin INTL Serenity (The Flying Squirrel)
2019 F250 DIESEL (Ferdinand)
mattRox is offline   Reply With Quote
Old 03-26-2020, 01:03 PM   #2
Mollysdad's Avatar
At my house, I have three also. They're clean outs. So many because I have one line from the kitchen and another from the bathroom, they "Y" just before the street connection.
It all goes the same place, downhill, so to speak. Use one that's convenient.
Old 03-27-2020, 08:06 AM   #3
Lewisville , Texas
Great!
Thanks so much,
Matt & Roxanne
Old 03-27-2020, 11:56 AM   #4
2007 27' International CCD FB
San Diego , California
Agreed and it's a matter of whichever is in a more convenient place.
I happen to have a clean out alongside the house right where I park my AS. I leave a slinky plumbed in on ramped support setup semi-permanently. Couldn't be easier to dump as it's just a matter of opening a cap on the end of the slinky, hook her up, and let her rip.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is online now   Reply With Quote
Old 03-27-2020, 12:48 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
As far as legal, don't ask don't tell, play dumb. After all it's the same old ****. If you ask planning and zoning they may not understand what you are talking about. It may or may not be technically illegal, but once they tell you no you are out of excuses.
Don't do a cousin Ernie though, but if you do the cigar does help.
Lumatic is online now   Reply With Quote
Old 03-28-2020, 01:23 PM   #6
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
First, I am not a plumber, but maybe one will chime in to prove/disprove my thoughts below.
I was under the impression that the reason for two cleanouts near the house was because one angled towards the house and the other angled towards the city sewer line. This was to make it easier for a plumber to "snake" towards the direction of a clog.
If that's true (and I'd look inside to see if it were so) then it would be best to select the opening that angles away from the house. Although either one should work, especially if you do the gray water final flush.
rowiebowie is offline   Reply With Quote
Old 03-28-2020, 01:30 PM   #7
Lewisville , Texas
Thanks for the answers!
I looked it up and found this:
Double Clean Out The most popular type used for modern installation, the double clean out has two shafts which connect to the lateral pipe forming a U shape. The cap closer to your home provides easy access to the city end while the cap closer to the street allows you to maintain the house end of the lateral.
Based on this I guess I should use the cap closer to my home.
Thanks again,
Matt & Roxanne
Drain Line Vent Questions for Experienced Plumbers dbj216 Waste Systems, Tanks & Totes 7 01-01-2014 06:29 PM
Plumbers, Help ! PVC fittings with ABS pipes alumascoupe Plumbing - Systems & Fixtures 18 08-25-2013 04:48 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
Plumbers Putty Buttercup Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 08-10-2005 02:28 PM
Plumbers, and those w/ plumbing experience: Chuck Our Community 1 02-15-2003 06:54 AM
