10-17-2018, 11:35 AM
Milford Center
, Ohio
Newbie: tow vehicle cable routing
Newbie here!! Just traded in Class C Redhawk. Now proud owner of a 2019 25FB Twin Flying Cloud. The dealer ran the tv hookup cable thru the little cutout on the bottom of the propane tank cover. The same cutout that the emergency brake controller wires run thru. It seems too tight for both of them and would eventually cause wear or even cut into the cable!! Also, this puts the tv hookup cable coming out right above the emergency brake controller. Is this configuration correct? Seem that a better setup would be to run the hookup cable out the bottom of the propane cover on the outside of the frame. Thanks!!!
10-17-2018, 06:42 PM
1987 25' Sovereign
Fort Collins
Picture?
Alumacoot
“We are confronted with insurmountable opportunities.”
10-17-2018, 06:53 PM
2012 27' Flying Cloud
W
, New England
Your instinct is correct. I didn’t realize it until year two when the cutout of the propane cover had stripped some of the cover off the cable and caused sparks - next to the propane tanks of course....
My solution was to wrap the power jack cable in a thick nylon hose. A rubber grommet in the cut of the tank would be just as effective.
I also run the 7-pin under the a-frame.
Good luck!
10-18-2018, 04:19 AM
Milford Center
, Ohio
10-18-2018, 05:51 AM
2018 25' International
Mound
My 2018 does not run through that hole. It runs through the bottom of the propane housing and outside (not through) the frame on the driver side.
10-18-2018, 02:09 PM
Milford Center
, Ohio
Thanks... that is how I plan to route my 7 pin cable! Seems the best way to me. Added extra shielding to jack wires and routed 7 pin cable over A frame and out bottom of propane shroud.
10-19-2018, 07:16 AM
2018 30' Classic
Jacksonville
[QUOTE=Sherlock628;2169231]Newbie here!! Just traded in Class C Redhawk. Now proud owner of a 2019 25FB Twin Flying Cloud. ……../QUOTE]
If you traded in an RV you are not that much a "newbie". I've met some new AS owners that the trailer was their first RV. They, at first, didn't have a tow vehicle and would rent a truck to move it around.
10-19-2018, 11:41 AM
Milford Center
, Ohio
[QUOTE=Overstreet;2169896]
OK.. I am a "newbie" to Airstream. After all, this is an Airstream forum, not an RV forum!
10-20-2018, 07:06 AM
W
, New England
Here’s a couple pics of what I did. The cable for the jack power seems like it has to come out from under the propane cover so that’s wrapped in a thick nylon hose (rubber grommet in the cover would have worked too). Then the 7-pin comes out under the bottom of the LP cover.
