08-15-2019, 11:30 AM
#21
2002 30' Classic S/O
Fleming Island
Some, but maybe not all, newer ITBCs use brake pedal pressure to decide how much voltage to apply to the trailer brakes. While sitting still in my 2013 Ram 2500, the harder I press the brake pedal, the more voltage is applied.
Electric brakes may not be linear, but they are proportional; the more voltage is applied, the harder they brake.
As perryg said, you should have your controller gain set to just below the point where the brakes lock up. The neat thing with discs is they are more repeatable. The drum brakes will fade when hot or wet. Even mild stops will cause decreased braking power. I discovered that with my tests referenced above.
Al
05-14-2021, 01:52 PM
#22
2016 30' International
redondo beach
Originally Posted by rmkrum
As the department of Overkill Engineering says, “if it isn’t broken, break it, and fix it to be even better...”
If it is not broken your overlooking something.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
05-14-2021, 02:51 PM
#23
2007 22' International CCD
Corona
I have a nice set of hammers of all kinds and sizes, and have been known to break stuff with big pipe wrenches…of which I have a good assortment.
05-14-2021, 04:13 PM
#24
2007 30' Classic S/O
Somewhere
, South Carolina
I've taken working stuff apart (furnace sail switch) just to see the rascal.
And yes it still works.
05-14-2021, 04:22 PM
#25
2004 30' Classic
California
, MD
Originally Posted by Mike S.
Pretty sure the disc brakes are not available for the newer Airstream trailers. I have a 2014 with never lube bearings and hubs, and none were available a year ago. Ended up taking the auto adjuster brakes off, and installed manual adjustment brakes instead. At least they won't run hot now. Had an issue where individual hubs would be hot enough for grease to come out of the bearings. No way to put the grease back in, so that wasn't good. Once a year I get to jack up the trailer and adjust the brakes. And I got a spare bearing cartridge. Since I have a spare now, I will never need it.
In a month the AS Service Center is installing Never-Lube axles on our 30 Classic and Dexter Disc Brakes.
2004 30' Airstream Classic
05-14-2021, 10:52 PM
#26
redondo beach
Thats too long a drive for me. We need a west coast version.
05-14-2021, 10:53 PM
#27
redondo beach
Picture in a new thread would be nice.
05-14-2021, 10:58 PM
#28
redondo beach
But you have an 04, will they do it on a new trailer?
05-16-2021, 07:27 AM
#29
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Converting brakes is not an assembly line option for Airstream.
We had seal failures on three of the four Never-Lube Dexter bearings on our 2014 31' Classic in 2020 with a disc brake conversion to Kodiak calipers in 2015. Dexter charged $800 for the four replacement bearings. They said they were discontinuing that bearing and ours were among the few that were left in inventory....
