Old 01-19-2020, 05:14 PM   #1
1983 34' Excella
Greenwood , Indiana
Leveling with bottle jacks
Has anyone tried to level. With like 6 boltte jacks. Placed on the frame supporting g in the middle also. What are the drawbacks. ... 34' excella. Seems might be a better way to level and stop swaying. I park for 3 to 6 months at a time. Im a travel nurse.. thanks in advance.
Jmptravelrn is offline   Reply With Quote
Old 01-19-2020, 06:03 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Jacks are for stability, not leveling. Airstream frames are very flexible and you could do some damage by trying to level with bottle jacks.
Use stacking or curved levels under the wheels to level side to side, then adjust the tongue jack to level front to back. Then deploy the stabilizer jacks to prevent bouncing.
As a bonus, use x-chocks or a similar style chock for tandem axle trailers to help prevent bouncing. Just one x-chock helps a lot.
TheGreatleys is offline   Reply With Quote
Old 01-19-2020, 07:11 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
No....level with the tires and hitch jack...use stabilizers...as stabilizers only
Old 01-19-2020, 08:05 PM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Do not use bottle jacks you will bend the frame. Use tires to level and x chocks and stabilizers to prevent swaying
GMFL is online now   Reply With Quote
Old 01-19-2020, 08:53 PM   #5
1983 34' Excella
Greenwood , Indiana
Thank you
Yes i have all those. Wedges. Blocks. And 4 of the xlocks between tires. Plus i have 4 x crank down stabilizers. I was just thinking if i used bottle jacks all the way around i would remove the weight off the tires and suspension and would be easier to level for the duration if the stay. I like to pull forward and back ever few weeks to avoid flat spots on tires. And its just such a pain to re level each time. I was thi ki g of using a 4 x4 along the frame rail on both sides to lift it equally.
Old 01-19-2020, 09:00 PM   #6
Maniacal Engineer
barts's Avatar
Menlo Park , California
You can level your Airstream a few inches with bottle jacks, but ONLY if they're placed so as to support the axle plate; the rest of the frame is not designed for concentrated loads such as those from leveling jacks (as opposed to stabilizers). This is how one replaces axles, brakes or changes tires; it's safe.
Note of course, that these must be screw jacks; hydraulic ones will slowly (or not so slowly) leak down.
Bottle jacks have somewhat narrow bases, so rough or irregular surfaces can be problematic, and lifting more than 3 inches is likely a bad idea.
Remember to remove them before driving away!
- Bart
Bart Smaalders
Menlo Park, CA
https://tinpickle.blogspot.com
https://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-20-2020, 10:03 AM   #7
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I imagine most every RV owners park their RV for months, probably over winter, at some point for many months at a time. While not ideal we all mostly seem to survive.
Pretty sure my airstream manual says not to try leveling the trailer with the stabilizer jack's, so as others have noted, for the same reason not to use bottle jack's at those locations either.
What you could do is inflate all trailer tires to their maximum pressure to minimize sidewall flex while parked (remembering to lower pressure back prior to departure), and use jacks at the designated jack points to lift the trailer slightly to remove some, but not all, the load off the tires. That's probably more than good enough.
kscherzi is offline   Reply With Quote
Old 01-20-2020, 10:23 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
X chocks and AS stabilizers to stabilze your AS once level. I would not use bottle jacks.
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-20-2020, 10:24 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I do exactly that.👍
ID:	359494   Click image for larger version
ID:	359496   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Growing Old…being able to think about things you can no longer remember.”
RLC
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 01-20-2020, 10:31 AM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by ROBERT CROSS View Post
I do exactly that.👍
......Why...?
Old 01-20-2020, 11:15 AM   #11
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by tjdonahoe View Post
......Why...?
Do you know where he lives?
Old 01-26-2020, 12:30 PM   #12
2019 27' International
The Woodlands , TX
Someone partially described what has worked so far for me when docked for some time and I'll add some detail and rationale. I don't think jacking the frame is a good idea. I find the LevelMate Pro very useful for the whole process. I first level side to side using the curved leveler blocks and the corresponding chock on BOTH sides of the trailer (levels the trailer, gets all 4 tires off the ground to reduce the risk of rotting the tires and provides a curved surface to the tires to increase the tire contact areas and hopefully reduces the risk of flat spots). I use the tongue jack to level fore and aft and place tire covers over the tires to reduce rot from the sun. I lower the 4 scissor jacks gingerly to stabilize the trailer and add 2 X-jacks between the tires on each side to add stabilization. I also learned to go back after a day or so to ratchet down the 4 scissor jacks SLIGHTLY and tighten the 2 X-chocks between the tires to compensate for any settling and make the trailer less wobbly.
aaurbane is offline   Reply With Quote
Bottle Jacks for more stability while staying static for a long period of time NeuroNerd411 Full-Timing 24 01-07-2020 06:58 PM
Stablizer jacks replacement with scissor jacks spoonplug Jacks, Stabilizers, Lifting and Leveling 18 11-25-2018 07:22 AM
As long as we’re talking about bottle-jacks ... AIRHEDS Jacks, Stabilizers, Lifting and Leveling 17 07-03-2018 04:33 PM
Bottle Jacks Distantdrummer Jacks, Stabilizers, Lifting and Leveling 8 10-30-2010 11:01 AM
