Old 09-26-2019, 08:25 PM   #1
Question How to best hang a sign on exterior door?
My parents are finally fulfilling their dream and getting an Airstream! My dad remembers camping with his grandparents in their Airstream as a kid in the Appalachian mountains. He told me he loved seeing the signs that people would hang on their Airstreams with their family name. It made it a little easier to introduce yourself to your campground neighbors and get to know one another.
To celebrate my parents' new trailer, I’m making a sign with our family name that they can hang on their Airstream. I’m planning on making it out of a small slab of wood and painting our family name on it. I’m curious if anyone has a recommendation on how to fix the sign to the exterior of the Airstream door. How would you design the hanging hardware so it won’t scratch the door when the door opens and closes?
Thank you, all!
jennakrack is offline   Reply With Quote
Old 09-26-2019, 08:34 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Since the doors are aluminum things like magnets really don't do the trick. There are several approaches with signs:
1) Mount then to the hitch area of the trailer on a pole. Flagpole mounts are often used
2) Hang then from the awning (only works if the awning is out and it will not always be out
3) Mount then on a stick in the ground pole
This all assumes that the sign is taken down when the trailer is in motion.
If you want the sign permanently on the trailer, first consider how durable it is. 60 MPH dirt / rain / grit are what it will see a lot of. If it will take that (and sun and heat and freezing ...) then VHB tape will quite solidly stick it on the trailer.
Old 09-27-2019, 06:32 AM   #3
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Or could it hang on the screen door when set up at camp
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 09-27-2019, 08:21 AM   #4
VeloBuckeye's Avatar
2018 27' Flying Cloud
Easton , PA
Consider strong suction cups -- if the location can be to the side of the open door, on the outside wall of the AS. Easy to mount/remove with no damage or scratching.
VeloBuckeye
2018 Flying Cloud 27FB - "The Shoe"
VeloBuckeye is offline   Reply With Quote
Old 09-27-2019, 08:33 AM   #5
Rich W's Avatar
I'm In , Kentucky
We found someone on Etsy who makes signs. We post ours somewhere near the hitch. It seems to do the trick, people will stop if we are sitting outside.
This is the mock up we emailed to them, but the sign is exactly like this. It comes apart for storage when traveling.
Name:	Sign Mockup.png
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 09-27-2019, 10:16 AM   #6
2004 22' Safari
Albuquerque , New Mexico
Thank you, all!
Use suction cups and put it on the front window.
Silver.Sanctuary is offline   Reply With Quote
Old 09-27-2019, 11:41 AM   #7
2019 25' International
Washington , Washington, D.C.
There is a couple in NC (?) who make the most awesome customized signs stenciled out of aluminum that replaces the screen door shield (at least the one in my Airstream). It shows up well when main door is open and screen door shut; and surprisingly well when both door are shut and interior lights are on. I will look up name and get back to you- they had a kiosk at the Salem international rally in 2018. I believe he or she is a veteran. We went back and forth over several days with different designs until I saw the perfect one. I really hope they’re still in business because I’ve changed my mind about what I’ve named my AS. Ha!
PatLee is offline   Reply With Quote
Old 09-27-2019, 12:08 PM   #8
Nomad518's Avatar
2001 25' Safari
Ridgefield , Washington
Put a small easel back on the sign and set it on top of the propane tank cover at the front of the trailer.
Nomad518 is offline   Reply With Quote
Old 09-27-2019, 03:09 PM   #9
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
we hang from our front window rock guard when its open....if they have a rock gard
rucos is offline   Reply With Quote
Old 09-27-2019, 03:50 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If they have a flagpole mount on the AS, it can hang from that.. they can remove or leave when traveling.. the way the mount is made, there is a flat face facing forward where you could hang or wire tie or screw down..
Any movement on the aluminum will chafe the finish... won't be a happy thing.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-27-2019, 04:01 PM   #11
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Look online. We got an Airstream silhouette decal with family name that goes on inside of window. I’d send a picture but we’re not home ...
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Old 09-29-2019, 12:15 PM   #12
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
I would epoxy two or four magnets on the back of the sign, with two or four corresponding steel washers epoxied on the screen door. This way it can be removed as necessary.
3wd67rg is offline   Reply With Quote
Old 09-30-2019, 09:23 PM   #13
Peter D
MetalMissile's Avatar
2019 27' Globetrotter
San Luis Obispo , California
Infinite Vinyl signs
If you really want to blow your parent's mind, have it "wrapped" with your family name in 36 inch letters so the entire coach is emblazoned with your family name. Do it at an angle for art's sake.
Just slightly but not entirely kidding. the creative options are endless.
The other end of that spectrum is a vinyl sticker the size of a bumper sticker or smaller that can be placed near the door. Easily removed without marring the aluminum or the finish, won't interfere with door operation and don't need to make holes or mess with magnets. Have several printed to when one fades, another one is placed fresh.
Many graphic design and print shops can make your selected graphic design in vinyl, from small to huge, and can make several if you want the name front and back.
metalmissile.
MetalMissile is offline   Reply With Quote
Airstream International exterior sign no1sandman Airstream Classifieds 0 05-25-2017 11:02 PM
Best places to hang out in Utah/Colorado Marygb On The Road... 17 03-13-2017 06:54 PM
Re-hang bedroom door Minnie's Mate General Repair Forum 0 06-27-2007 09:32 AM
Hang on to those quarters Pahaska Off Topic Forum 9 01-25-2004 09:26 AM
Part needed to hang curtains Herm and Debby Upholstery, Blinds, Walls & Interior Finishes 6 07-22-2003 05:53 AM
