Go Back   Airstream Forums > Airstream Community Forums > Our Community
Old 06-16-2020, 09:20 AM   #1
Johnson City , Tennessee
Hitch to AS
So I really want to use my hitch mounted bike rack. Saw that Cliffs out of Mesa AZ has done some work to some youtubers. What has everyone else’s experience been like? Anyone use this?
What would be some suggestions?
Don’t want to use tow vehicle. Looking for only hitching to rear of AS
Navymed_19 is offline   Reply With Quote
Old 06-16-2020, 09:49 AM   #2
1986 31' Sovereign
Miami , Florida
For years the accepted wisdom was “do not put a hitch on the back of your Airstream”. The main reason offered is that the arm/moment that far behind the axles leads to excessive loads which will damage the frame and/or cause shell to frame separation.
The Fiamma rack that Airstream now sells/installs gets around that by also having an attachment point on the semi-monocoque shell.
Having said that, there are folks (hopefully some will weigh in) that have done exactly what you propose to do with no ill effects.
Personally, I wouldn’t do it. I figure that if the Airstream engineers went with the Fiamma, there was a reason for it.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 06-16-2020, 11:09 AM   #3
2018 25' International
Slidell , Louisiana
I ran some stress and strain numbers and I can say the Airstream engineers are not concerned about the hitch, any added platform or a couple of bikes, but there is an engineering design principle that the attached devices should be weaker than both the mount and what it is mounted to. Since this is not the case, and the rear frame can flex too much especially if the device added to the receiver extends backward a ways and say gets rear ended or bottoms out badly or even if someone overloads the receiver with a large basket with heavy items. So if this happens the aluminum sheets are likely get creased.
So If you're willing to take that risk, this is a fine option.
Old 06-16-2020, 11:09 AM   #4
Problem is that with that rack you are super limited: only 2 bikes and a gigantor rack that has no other uses
Old 06-16-2020, 12:34 PM   #5
skitger's Avatar
2022 25' Flying Cloud
2018 16' Sport
1962 22' Safari
Corvallis , Oregon
There is always a front hitch option, I went that way, not perfect either. But I could use my existing rack and there was a bolt-on hitch for my rig. There are lots of threads on this topic too. Hope you find a solution!
Rick & Paula LaMont
2022 Flying Cloud 25’ FBQ
WBCCI #7944
skitger is offline   Reply With Quote
Old 06-16-2020, 02:17 PM   #6
1986 31' Sovereign
Miami , Florida
I went front hitch. The bikes get filthy but that is the only down side.
Young, lovely bride
Dismissive cat
Air Safe Air Hitch and WD hitch combo JBCrete2 Hitches, Couplers & Balls 19 07-17-2022 03:54 PM
Top Rated Sway Control Hitch (Hensley Hitch) Dgresham Airstream Classifieds 0 08-27-2014 10:20 AM
Reese hitch or Equalizer hitch? mouth012006 Hitches, Couplers & Balls 4 03-04-2010 07:31 PM
An exquisitely bad idea, AKA the hitch of death or the sway-enhanced hitch Jammer Hitches, Couplers & Balls 8 01-20-2010 04:40 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
