Old 12-04-2018, 12:33 AM   #41
2019 22' Sport
I’d personally go for the Kodiak inergy solar generator, it seems better then goal zero in a lot of ways. Including recharge time and number of recharges. Plus it has an Rv plug.
https://inergytek.com/products/kodiak
Kanusport is offline   Reply With Quote
Old 12-04-2018, 08:17 AM   #42
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Originally Posted by AirNubie View Post
Have a Goal Zero 1000 which does a great job for some extra power in our TT. Thinking of buying 3 more and just plugging them into the 110 service for extra juice when boondocking (for ~$3,000)-- VS. going to the trouble of installing 3 Battle Born batteries (which would run ~$4,000-$5,000 installed)
Both would provide about 300 Amp hours of power; both are lithium... and the Goal Zero has the added benefit of portability in case I need the power elsewhere (or if I swap into a new TT... easy).
Pros? Cons? Thanks for all wisdom and perspective!
Hi
Ok, with amp hours, the voltage matters. If I take a BB battery, it has four banks of 3V cells in it. They are in series so the current adds when run at 12V. If you looked at it the way Goal Zero does (at 3V) the 100AH BB would be a 400AH device.
With a Goal Zero 1000, you get 1,045 watt hours of power. With a single BB lithium you get 1,320 watt hours of usable power. With a typical flooded lead acid group 24 you get 480 watt hours of usable power.
Lithium Alternative - Goal Zero Yeti 3000 Tronadora Sprinter and B-van Forum 76 05-17-2020 09:44 PM
Goal Zero 1000 Lithium Costco chaeha Generators & Solar Power 28 04-19-2019 03:42 PM
Goal Zero Lighthouse 250 LED Lantern pappy19 On The Road... 17 12-31-2014 01:49 PM
AimZero- zero grid, zero feul, zero discomfort, zero nonsense. greenlinks Off Topic Forum 14 01-03-2014 08:13 PM
