Old 02-26-2021, 08:04 AM   #1
maugerville , New Brunswick
frame
what is the best way to remove the shell from 1972 ambassador
terry1000 is offline   Reply With Quote
Old 02-26-2021, 08:31 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
In my opinion, the best way to do it is to build a pair of gantries and lift the shell using them. The gantries have lots of other uses as well. Search the forums for "gantries", and you should find a schematic showing how to build them, and lots of threads describing their use.
good luck!
Old 02-26-2021, 12:08 PM   #3
Long Island , New York
Welcome to the forum.
These "shell off" search results should lead to some productive reading:
https://www.google.com/search?q=shel...=airforums.com
Many of the threads are located in the "Repairing . . . Frame" sub-forum:
https://www.airforums.com/forums/f36/
Good luck.
Let the music lift you up . . .
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 08:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
