Old 06-13-2021, 09:20 AM   #1
David Perri's Avatar
2016 25' Flying Cloud
Wading River , New York
Electrical failure
Hi Guys, I'm in Montauk NY camping and have lost 110 power. No AC power inside the unit, nothing at the main circuit breaker or any outlet. power supply is a working generator, verified cable is good. I would have to believe there is an open somewhere between the out side shore power connection(I've tried both front and side plugs with same the same result.
So my question is this, Is there another inline fuse or circuit breaker that might be tripped? I can't seem to find any in the owners manual.
Thank you ...hope you can assist.
Dave
David Perri is offline   Reply With Quote
Old 06-13-2021, 09:24 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
David,
Does your trailer have a dual power connection package? Shore power at the rear, gen at the front. Maybe the generator transfer switch failed.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 06-13-2021, 09:32 AM   #3
Originally Posted by GCinSC2 View Post
David,
Gary
That's a good question, I'm not a where if there is....t
is that standard equipment? and i so where would that switch be located
Old 06-13-2021, 09:35 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If it has two inlet plugs it has to have the switch. There have been a lot of reports of the switch failing. Seems like your trailer is in the time period for that problem. I do not have but one inlet so I do not know where the switch is located.
I doubt if there is a work around. There is a real big safety issue involved here. Maybe just get a charger for the batteries to keep them going and run an extension cord into the trailer for the 110 power until you can get it fixed.
Old 06-13-2021, 09:42 AM   #5
Originally Posted by Bill M. View Post
If it has two inlet plugs it has to have the switch. There have been a lot of reports of the switch failing. I do not have one so do not know about them.
I doubt if there is a work around unless you can completely disconnect one inlet and bypass the switch for one inlet to use. There is a real big safety issue involved here. Maybe just get a charger for the batteries to keep them going and run an extension cord into the trailer for power until you can get it fixed.
good advice....just going to recharge batteries and look at once I get home.
Thanks Bill
Old 06-13-2021, 11:59 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Any chance the genny overloaded and is not generating current? Could not tell from your post whether you had power at the genny outlet.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-16-2021, 04:46 AM   #7
HI Guys,
Thanks for your advice, It turned out to be the Progressive Industries by pass remote, effectively its a transfer switch I didn't have it on.
All is good.
Dave
Old 06-16-2021, 05:05 AM   #8
GCinSC2's Avatar
Just curious and glad it's working. Is this the item?
https://www.progressiveindustries.ne...ass-switch-kit
From their website:
"EMS-LCHW ByPass Switch Kit (for use with EMS-LCHW50 & EMS-LCHW30 series only)
EMS-LCHW ByPass Switch Kit enables user to add a remote bypass switch for emergency use."
S/OS #001
2017 22FB electrical issue and Dometic RM8505 failure mlonas Electrical - Systems, Generators, Batteries & Solar 0 06-26-2019 09:52 PM
MB Sprinter Electrical failure wildwilly. Sprinter and B-van Forum 4 09-05-2018 01:08 PM
ADVISORY - Electrical converter failure hazards InterBlog Sprinter and B-van Forum 0 03-07-2016 05:12 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Electrical failure ralley Mechanics Corner - Engines, Transmission & More... 8 11-16-2008 10:15 PM
