I just ordered 4 of these TPMS system … Setting the tire pressures up easy within my range is I have a 20 foot Bambi 2018 does anyone know what my max air should be in those tires? 80? What should I run at about 65? And then what should my top sensor temperature gage be 80 or 85 ? how much of my lower? 50? ? I’m a little confused with the ranges tire pressure monitor system set thanks I’m very new to this Andrea
You will need to determine what the best pressure is for your trailer. Tire brand and rating along with the weight on the tires are all factors. The max tire pressure will be indicated on the sidewall of your tires.
Once your pressure is determined, the range is normally set at + 20% for the high limit and - 10% for the low.
If 60 PSI is your normal, then your limits would be 72 (high) and 54 (low).
Richard Wally Byam Airstream Club 7513
