06-12-2021, 09:46 AM
Living the Airstream Life
2016 30' Classic
Cypress
Dometic AC in 2016 Airstream Classic 30’
Hi All,
I’m hoping someone can advise, need help with 2nd Dometic AC unit in AS Classic. The front unit works perfectly, but the smaller (13500) unit in the back blows out room temp air, but not all the time. If the front unit is turned on and set for around 74, and the back unit is turned off or turned up to 90 degrees, then cold air is coming out of the back unit but not really blowing like it does when fan is on. Sometimes, if the front unit has cooled down the cabin, can turn on the back unit and it will actually work, compressor, cold air blowing.
Most perplexed-obviously it’s not a Freon issue since at times it actually works. Could it be the thermostat? Welcome ANY ideas. Heat index in Texas today over 100 and have 2 large black dogs! Thanks.
06-12-2021, 09:58 AM
2017 30' International
Broomfield
I would do 3 things:
1. Turn off the front AC for this test
2. Remove and clean the ceiling-mounted filters located just under both AC units
3. Turn the temp down as low it will go in bedroom zone with AC on to force cooling action
See if you get cold air. If you do then turn on main AC with low temp to force cooling on main unit.
That will take about 5 minutes... maybe you can report back on if that helps?
06-12-2021, 10:09 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Only thing I'd add to that is to be very sure all the vents are open. They tend to rattle shut ..... I have data on this ....
06-12-2021, 01:20 PM
Everyday is a GIFT !!
2015 30' Classic
Collins
, Mississippi
Ouch 🥵. I had the issue a few months back. Turned out my ac fan motor was going out when it worked it was cool when it didn’t it was not cool even though the unit was running. Once that was replaced all was well.
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
06-13-2021, 03:21 PM
2016 30' Classic
Cypress
Thanks for your suggestion-so cleaned filters yesterday. Went through your steps and waited at least 5”-air blowing robustly but still not cool.
2016 30' Classic
Cypress
Thanks for your reply and suggestion- double checked and the vents are all open and the filters are all clean.
06-13-2021, 03:23 PM
2016 30' Classic
Cypress
Could you hear it running the entire time, even though it was going out? Lots of air movement and sounds like fans are normal, but air isn’t cool. Thanks!
1988 34' Limited
Mobile
, Georgia
The only other user maintenance item is getting on the roof, taking the cover off and cleaning (with water) the coils. While you have the cover off (with power off the rig) check for loose wires etc.
Other than that it's time to call a tech.
06-13-2021, 03:37 PM
2016 30' Classic
Cypress
So bought a replacement Dometic Penguins 2 (13500)-does anyone think it’s worth a try to switch out the whole back AC unit or the capacitor only? Don’t know enough to determine, so welcome input. Thanks.
06-13-2021, 04:53 PM
2015 30' Classic
Collins
, Mississippi
I replaced the whole unit. My parents have an identical unit like mine…… same issue. We replaced the av in both units. Sorry you have that issue.
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
06-13-2021, 04:56 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Capacitors can be tested easily with a decent multimeter.
06-13-2021, 05:07 PM
1988 34' Limited
Mobile
, Georgia
Replacing the capacitor is the cheaper option - $15 and an hour of your time. If you've already purchased another AC though...
This is a good video on how the capacitors work and how to check them.
06-14-2021, 07:59 AM
2016 28' International
Alabaster
, Alabama
I had the same issue with our 2016 Serenity. Replaced the complete unit last year, solved the problem.
06-15-2021, 08:35 AM
2016 30' Classic
Cypress
Another question, has anyone actually replaced their Dometic AC on their AS themselves and, if so, how difficult/time consuming was it? Thanks.
06-15-2021, 09:17 AM
1988 34' Limited
Mobile
, Georgia
Once the inside surround comes off the rooftop portion of the AC is held on with 4 long bolts. Once those come out, the rooftop portion is free. I removed mine with some carpet remnants (to keep it from scratching the outer skin) a scaffold and two people to move it from the roof to the scaffold then down to the ground. Some people have rented forklifts, lulls, or made gantries to lower it from the roof. There are plenty of videos on youtube, it's not a hard job with the right planning.
