RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-25-2021, 01:20 AM   #1
2021 16' Caravel
Kirkland , Washington
Do trailers tilt backwards while traveling?
Hi all,
When dealership installed our hitch and WD, they adjusted the hitch ball rise/drop so the trailer was level, which is good. However, I think it's only level when the trailer is stationary. When the trailer is moving @ 65mph, wind puts tremendous force against the body of the trailer, mostly above the axle, This would create a force for the trailer to tilt backward.
I do not know how much does my trailer tilt, but I am a little worried as this would put the solar panel at a positive 'angle of attack', which can generate a strong lifting force that could rip the panel off roof, I think this is especially a concern on my small 16' trailer, as the panel is fairly close to the front of the body.
I am wondering if anyone has experience/data of this, like the degrees of the tilting. I guess I could try to tape a level on the floor and put a gopro next to it but I want to see if someone has done this and already has data.
Thanks!
hovr is offline   Reply With Quote
Old 01-25-2021, 05:22 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I think you may be over thinking this.....there is not much flex in a trailer chassis or the truck hitch, so if it is level, it is level. But, few roads are level for long runs. Sometimes you are going up, sometimes you are going down, always changing the position from level. If you are worried your panel will fly off, do a better job of attaching it. There are many, many miles of travel with solar panels not flying off. I am sure some panels, not attached properly, have taken flight, though.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-25-2021, 05:22 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Never even though about that. I have seen a lot of trailers traveling down the road. Never noticed any tilt that was not there when it was sitting still. It seems to me that it pivots around the ball when hooked up. And with the WD applied it must move both the TV height and the trailer height. I doubt if there is much tilt.
Old 01-25-2021, 05:51 AM   #4
Long Island , New York
Well said Larry, if a bit diplomatic . . .
"Let the Music Lift You Up!"
Peter
Old 01-25-2021, 06:03 AM   #5
Bethlehem , Pennsylvania
Short answer: no
Merlintiaga is offline   Reply With Quote
Old 01-25-2021, 07:19 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Really worried?
Drop the tongue an inch, better low than high, level is best.
Our panels may blow over but not off.😂
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
Old 01-25-2021, 07:25 AM   #7
Really worried?
John Turley
Tahawus
Old 01-25-2021, 08:33 AM   #8
2018 25' International
Slidell , Louisiana
Even with a vehicle in front and an articulating connection (the ball and coupler), wind forces are largely balanced on the center of the net exposed cross sectional area. Rotational force therefore only occurs if the trailer center of gravity is not aligned and in the case of an airstream they are within a foot or so. I estimate downward force on the axle between 40 and 120 lb and upward force on the ball 10-20 lb. Net change in level would be less than 3/16 of an inch.
To Larry's point that dynamic forces are much greater (they are), but the holding force of even one sheet metal screw plus the sealant is ten times that required to keep the panel in place because the flat panel is not very good airfoil so not much lift is generated. Rest easy.
Old 01-25-2021, 10:09 AM   #9
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I must say that has never entered my mind ... after 20 year our AS has travelled North America the solar panels are still attached - besides that I have other things to think about, like breakfast....
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-25-2021, 10:20 AM   #10
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Interesting.
Next time I go take it out, I will turn on my LevelMate Pro and keep an eye on it. Since I typically rent a FORD, they have an OFF-ROAD feature that also monitors the position of the vehicle. I can compare the readings and see what exactly is happening.
If you don't have a LevelMate Pro, get one. It is helpful but should help with your current situation.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 01-25-2021, 10:23 AM   #11
rlphillips00's Avatar
2016 23' International
Fort Davis , Texas
Level means level. Wind force may not be as great as you think. I keep my solar panel on the ground since half the time I park in the shade and 50 feet of cable does wonders for keeping the panel in the sun.
rlphillips00 is offline   Reply With Quote
Old 01-25-2021, 11:07 AM   #12
1988 32' Excella
Robbinsville , New Jersey
Don't forget you are pulling the trailer from the bottom with much more force then the air at the top, otherwise you would be going backwards. Also the AS is rounded at the top which might add down force.
Old 01-25-2021, 11:14 AM   #13
1964 30' Sovereign
Ione , CA
Keep it where the dealer set it. Dropping the tongue won't make any difference in the wind resistance of your solar panels but would then make (i) the trailer slope slightly downhill when you are in it while hitched; and (ii) reduce your ground clearance under trailer tongue. It will be fine where you have it. Just have any non-original panels mounted securely. Travel safe!
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 01-25-2021, 12:30 PM   #14
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
The solar panels, if lying flat, have approximately zero lift. I have watch un-attached panels during a thunderstorm an they stayed stationary, even with all the wind. That feature contributes to the use of the 3M bonded feet and sikaflex sealant mounted panels a lot of people are using these days. Mine have stayed on 5 years and with driving tests of 80 mph.
guskmg
Old 01-25-2021, 12:37 PM   #15
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Three Rivers , California
I'll second that and raise you a dinner...
twolanehwy is offline   Reply With Quote
Old 01-25-2021, 12:51 PM   #16
Slidell , Louisiana
There is rolling distance putting upward torque on the tongue....
Old 01-25-2021, 12:51 PM   #17
2020 33' Classic
Sarasota , Florida
If your rig is level front to back on level ground then you have no worries.
Gigler is offline   Reply With Quote
Old 01-25-2021, 02:22 PM   #18
Annapolis , Maryland
No tilt
Originally Posted by hovr View Post
Hi all,
Thanks!
I am not an engineer, but I do not see how a trailer with a weight distribution hitch can tilt, relative to the tow vehicle, unless the tilt is designed into the installation.
rhpeahl is offline   Reply With Quote
Old 01-25-2021, 03:00 PM   #19
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
If I were to draw a cartoon, I would show the trailer tilting backwards in order to convey speed.
Real life, no.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 01-25-2021, 04:38 PM   #20
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
One axle test - parked & loaded, raise all stabilizers up 2 inches, remove all other leveling stuff. Than gradually take up jack post up about 2 inches. Settles on back end stabilizers. Trailer goes up in front.. that is the problem. Move some stuff forward.
slow 55 from 65
Hehr vs. Full tilt windows. Soyboy Windows & Screens 28 03-17-2012 08:55 AM
turn signals backwards from truck mcair Lights - Interior & Exterior 7 06-02-2009 06:31 PM
Tilt Switch source? pwhittle Mechanics Corner - Engines, Transmission & More... 2 04-22-2009 08:38 AM
Tilt Mechanism - Lookout Blinds xengineer Upholstery, Blinds, Walls & Interior Finishes 0 09-01-2008 06:09 PM
WHY do airstream doors open backwards?? infinite LUX Our Community 5 12-05-2003 06:56 PM
