09-24-2022, 11:29 PM
Longview
, Arkansas
Cleaning a/c vents
Hi there everyone! Any suggestions?! Currently vacuuming every week then monthly-removing vents to wash filters. Concerned about stripping screws as seems excessive. We were told they needed cleaning frequently!?! Thank you for your experiences/methods. We have the 2021 30’ classic
09-25-2022, 02:35 AM
2023 23' International
Calgary
, Alberta
Maintenance Hints - A/C Vent Mods
Have a look at this video. It shows a vent modification that makes cleaning your filters easy and quick. The relevant section is at the 20 minute mark. You may want to watch the entire video as there are number of great maintenance suggestions.
09-25-2022, 05:46 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
I did the modification to the vents as mentioned in the video. Previous to the modification, no matter how hard I tried, it seemed as though I always dropped at least one of those little screws prompting and search on hands and knees.
So much easier now which allows for for more frequent cleaning.
Do it, I don't think you will be sorry!
09-25-2022, 06:07 AM
2020 25' Globetrotter
Hillsdale
, New York
I'm interested in two products from the video...
The "Step Stick"
and
The Jacknut kit.
Anybody have a link for each of these products?
SPP
09-25-2022, 06:14 AM
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
the mods look great, but seems to be a huge secret of where to obtain this kit that installs threaded inserts in your AC Vents. Anyone have a link to the kit?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
09-25-2022, 06:22 AM
1994 25' Excella
Waukesha
, Wisconsin
The "Step Stick"
and
The Jacknut kit.
SPP
If you watch the video on YouTube there is a link in the video description. It's a link to an email, not a website. Send him a message. I bought from him in the past and he responded quickly.
Richard
11018
09-25-2022, 06:26 AM
Freedom
2023 30' Classic
Dallas
, TX
Opps… Richard beat me to it.
2023 30 Foot Classic
2022 Ram 3500 Dually
09-25-2022, 06:29 AM
Hillsdale
, New York
Thanks...appreciate it!
SPP
09-26-2022, 07:33 AM
Tavares
SPP
Are you going to be at Alumalina by chance?
09-26-2022, 07:38 AM
Hillsdale
, New York
Nope...gettin g ready to pack it in for the season.
SPP
09-26-2022, 07:41 AM
Hillsdale
, New York
So just to follow up...
The AC vent modification is awesome, but unfortunately purchasing the kit including the tool is a bit costly for me. I wouldn't mind but the tool is only good for installing jack nuts, that is it will not also install a plain rivet....so that leaves me with a tool that I can't imagine using more than the one time to modify the vents.
SPP
09-26-2022, 09:40 AM
2017 25' International
West Lake Hills
SPP
EDIT: He says a rivnut will not work but I didn't exactly understand why at first. Seems it would to me if you drill out the hole with a sized bit and not that reamer. He simply used the wrong tool. A rivnut takes two wrenches to install. You probably already own the wrenches.
09-26-2022, 10:13 AM
Calgary
, Alberta
On-line sources
SPP
The tools and nuts, screws can all be found online. I am not sure what the cost of the kit is but is may be cheaper buying online. Another option may be a Jack nut friction tool. I have not used one but pleat of information on line. It is quite cheap (I am in Canada hence the Canadian supplier).
https://www.grainger.ca/en/product/J...H/p/POPJNT1100
09-26-2022, 11:15 AM
1994 25' Excella
Waukesha
, Wisconsin
The hole he was talking about was the one that was right up against the opening in the sheet metal. No matter how you enlarged the hole, it would overlap the rectangular opening. Without a full perimeter around the rivnut he was explaining that the rivnut will just push out sideways as you set it.
I believe this is the tool used to set the jack nuts. They also have a wide selection of jack nuts.
https://www.amazon.com/dp/B07PPL466Y...v_ov_lig_dp_it
Not trying to direct business away from him, but there are options out there for those who want to put together their own kit. You'd need to order the thumb screws, jack nuts, and the tool. I have no idea what he charges for the whole shebang, but it might not be any different once you add things up.
Richard
11018
09-26-2022, 12:48 PM
West Lake Hills
OK. I see that now.
I'd probably take a look before resorting to a jack nut. I wouldn't drill out a 5/16 inch hole if there was a problem. I'd try to use a smaller rivet nut. A 3mm rivet nut requires a hole a shade larger than a 3/16". And I certainly wouldn't drill that hole using a step bit while my view was obscured by the paper bowl. That's asking for trouble.
Alternatively, a clip-on nut might work nearly as well, and cost a fraction of any other option.
09-26-2022, 01:03 PM
1994 25' Excella
Waukesha
, Wisconsin
OK. I see that now.
I was thinking the same thing as I watched the video. A clip on nut could likely be found with the correct set-back, although some of the holes he was working with were much further back than others. With such various set-back distances it might require a couple of sizes.
Using the jack nuts probably results in the solution with the least future problems, as clip on nuts can move around and be difficult at times.
Richard
11018
09-26-2022, 04:46 PM
Hillsdale
, New York
The kit is $91 for a 1 AC application, $107 for 2 AC's.
Perhaps everything could be sourced for less money (stepped drill bit, jack nut tool, and jack nuts), but I would think probably for not MUCH less.
I just don't want to buy a $75 tool that I will only use once.
Too bad it won't install regular rivets as well...
SPP
09-26-2022, 04:55 PM
1994 25' Excella
Waukesha
, Wisconsin
SPP
You can get the tool from Amazon for about $15. Pretty sure the one I linked to is the same type he used in the video.
Richard
11018
09-26-2022, 06:56 PM
2022 25' Flying Cloud
Tualatin
, Oregon
Purchased from Amazon
Hilman Group jack nut
59122 6-32
Digikey 6-32 stainless thumb screw
1772-1376-ND
In this case you can get behind the jack nut after installation so I used a regular flat head nail and my pop rivet gun to collapse the nut. Drill the hole, push in the nut, drop a nail from the back side. Insert shaft into pop rivet gun and make a couple of gentle squeezes to set the nut. Open the pop rivet handles to release the nail, pull nail from back side of jack nut. You're done.
I did a couple of dry runs on a scrap piece of tin can.
Steve
09-26-2022, 08:33 PM
2021 20' Caravel
Plaistow
, New Hampshire
Noloxsolution@gmail.com
As long as i copied it correctly.
Learning and enjoying as we go !
