Old 10-11-2018, 03:42 PM   #1
2003 31' Classic
1976 31' Sovereign
Princeton , Minnesota
Camco 37463 3-Way By-Pass Valve Replacement
Any better ideas?
I went to winterize my 2018 FC and had to remove the hose to the water pump so I could install a plastic tube to pull antifreeze from my gallon jug.
That is one tight area in there and I was barely able to get my hands in there.
I determined I was not going to do this every winter. So I went to Menards and a Plumbling supply house. Not had a fitting that would fit in that confinement. I searched on the internet and found this valve from Camco. Not I can reach in there and attach my hose for my antifreeze.
SP in Minnesota
spfleghaar is offline   Reply With Quote
Old 10-11-2018, 03:50 PM   #2
2016 28' International
Sioux Falls , SD
Will the old connections fit onto it as well?
Good idea, I had the same issue on our 28’.
You will need a good cap though.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 10-11-2018, 04:22 PM   #3
2003 31' Classic
1976 31' Sovereign
I will take pictures when it is completed. Not sure what you mean by I will need a good cap. Yes the fittings are all .500 inch.
Old 10-11-2018, 04:56 PM   #4
Sioux Falls , SD
The end with the new hose will need a cap when not in use correct?
Old 10-11-2018, 05:25 PM   #5
2007 22' International CCD
Cap is needed more to keep dirt out and the threads clean--the valve cuts off the one input when it's turned to the correct position, and opens the other...
Old 10-12-2018, 11:24 AM   #6
2018 27' International
carbondale , Colorado
works great. Installed last year during my first winterization. Easy Will make doing it this year even easier. The cap I believe is just to keep the intake area clean. Valve shuts it off.
capt_ron777 is offline   Reply With Quote
Old 10-12-2018, 12:33 PM   #7
ObviouslyKnot
james.mileur's Avatar
2024 30' Classic
KALISPELL , Mt
I left my hose on, with a few inches of fluid above the valve, curled up and stowed. Was all there exactly the same waiting for me this year, ready to go.
James Mileur (& Belinda)
2024 Classic Twin, 2024 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Hot Water Heater By-Pass Valve Stuck RedDogBullet Water Heaters, Filters & Pumps 4 06-12-2012 10:00 PM
Camco Camper Drain Trap? brattwurzt Plumbing - Systems & Fixtures 1 08-20-2011 11:17 AM
GoldenAge Pass aka America The Beautiful-The National Parks & Federal Rec Lands Pass Driver1 Boondocking 16 07-22-2009 10:00 AM
Water heater by-pass valve position? TennisMan Water Heaters, Filters & Pumps 1 01-10-2009 09:45 PM
Camco Tornado Tank Rinsers beaubayou Waste Systems, Tanks & Totes 3 03-23-2008 01:53 PM
