Old 07-27-2018, 07:49 PM   #1
VLWino's Avatar
2017 25' Flying Cloud
Long Beach , California
Breakaway Switch popped out!
Quick question - if I accidentally tripped on the breakaway switch, which popped out, but then was able to easily pop it back in, will I have a problem leaving my site tomorrow? Will the trailer breaks be engaged, or is it fine as long as the pin is back in the breakaway switch? I have a 2017 25FB currently unhitched at a state park.
Quick answers appreciated to make the wife feel better!
VLWino is offline   Reply With Quote
Old 07-27-2018, 07:57 PM   #2
steverino's Avatar
2018 30' Classic
Ivins , Utah
As long as the pin is popped in, the brakes will be released. Nothing additional needed to do.
steverino is offline   Reply With Quote
Old 07-27-2018, 07:58 PM   #3
VLWino's Avatar
Thanks Steverino! We"ll sleep well now.
Old 07-27-2018, 10:02 PM   #4
Mollysdad's Avatar
No problem as long as it wasn't out long enough to drain your batteries.
My dealer demo'd the switch by pulling it out. Since the cable was so long he recommended tying a very loose knot in the cable, so it doesn't drag the ground, but would get tight in an emergency.
Old 07-28-2018, 10:37 AM   #5
1988 32' Excella
Robbinsville , New Jersey
Pulling the pin out occasionally with the trailer not plugged into the TV to test that the breakaway switch works is actually a really good idea.
Old 07-28-2018, 11:11 AM   #6
2018 30' Flying Cloud
Gig Harbor , Washington
Someone had popped mine out while in storage (no way to tell how long). I checked the magnetic brakes, looked good. Battery was low but not dead and I was able to re-charge. Has been working since with no problems.
hoagy_007 is offline   Reply With Quote
Old 07-28-2018, 03:47 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Caution: If you happen to have disc brakes, only leave the pull plug out a second or so. If left out longer the electrical load on the switch wiring will cause it to melt and short out. Eventually, the switch contacts weld together and you can no longer turn off the pump by replacing the plug. Unfortunately, no one makes a brake-away switch with wires large enough to handle the load an electric/hydraulic pump places on the wiring. I have had to change several because of this. It even happened at the Airstream Factory Service Center. Do not use the brake-away switch instead of chocks to keep the trailer from moving.
guskmg
Old 07-28-2018, 03:59 PM   #8
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
guskmg
In an actual break away will this lock the brakes on or will they fail?
Ray B.
Adventure.AS is offline   Reply With Quote
Older Eaz Lift- spring bar popped out when backing DJW Hitches, Couplers & Balls 1 05-28-2013 11:00 PM
Would you/did you buy it? Breakaway switch joatmon Brakes & Brake Controllers 3 05-11-2005 11:57 AM
12v reading lights '65. popped out ronmcor Electrical - Systems, Generators, Batteries & Solar 4 11-29-2004 07:07 PM
Testing breakaway switch Sneakinup Brakes & Brake Controllers 6 03-20-2004 10:45 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 03:09 PM
