06-04-2019, 11:51 AM
2016 23' Flying Cloud
Evergreen
Brake Work on Safari in Denver
We purchased a used 23ft, 2006 Safari last year and had some issues with the brakes getting hot coming down the Tetons.
Any recommendations on who can do brake work in the Denver area other than Windish and Camping World?
Thank you in advance.
06-04-2019, 12:19 PM
1979 23' Safari
1954 29' Liner
Orange
Luke Bernander in Loveland, CO
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
06-04-2019, 12:20 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Welcome to Airforums from SC.
Hot brakes on tow vehicle or trailer ?
And make model and year of tow vehicle would be interesting too. Do you know what brake controller is on tow vehicle?
Gary
06-04-2019, 12:25 PM
Evergreen
Thank You
06-04-2019, 12:26 PM
Evergreen
2018 f150
06-04-2019, 01:44 PM
Somewhere
, South Carolina
Ok brakes on F150 or trailer smoking, which one?
06-04-2019, 01:50 PM
1987 25' Sovereign
Fort Collins
Luke is in SW Fort Collins, not Loveland. 970-222-4065
Alumacoot
“We are confronted with insurmountable opportunities.”
06-04-2019, 02:07 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Keep in mind that the amount of braking on the trailer is controlled by the setting of the brake controller in your vehicle. Set it to high and you *will* fry your trailer brakes ... I have empirical data on this.
Anyplace that does work on commercial trucks and trailers should be very able to deal with Dexter brakes. There is noting special about the way AS uses them. There also is nothing special about how they do indeed have issues from time to time ....
06-04-2019, 02:09 PM
1979 23' Safari
1954 29' Liner
Orange
Sorry, thanks,
Bill
06-04-2019, 03:26 PM
2013 25' FB Flying Cloud
Longmont
I had Iron Bear trailer in Denver replace the axle on my Scamp last year. They did OK.
06-04-2019, 05:19 PM
2017 30' International
Broomfield
I've had good results with Transwest just up the road in Fredrick, just off I25 access road not too far north of E470.
06-05-2019, 06:45 AM
2016 20' Flying Cloud
Centennial
I just had some work done at this place. First time I have used them and was very impressed! B and B RV https://bb-rv.com/
Steve "Centennial Man"
06-05-2019, 02:27 PM
DR M
2011 34' Classic
Eastlake
I have had good luck going to Merrell which is off Colfax and Wadsworth.
2011 34' Limited Classic
2017 F350 King Ranch 4x4
06-06-2019, 10:16 AM
Evergreen
Perfect, thank you.
06-07-2019, 08:02 AM
2016 27' International
Anacortes
Keep one thing definitely in mind-and no one so far has said this:
Whoever does the work needs to know the only places to use jack-the jack locations are marked spots found when looking under the AS, typically behind the rear -most wheels. Check it out on yours. Do not use jacks under the axels like cars, as the axles can be damaged. Do not jack anywhere on the belly pan.
Others will chime in- but be very careful. A couple months ago I took our trailer to Discount Tire for new tires and I told the supervisor about where to jack and not to jack on the axles. Well, then a couple techs came out with their floor jacks and I said "NO!" do not jack under the axles, use the designated locations and yes-that means you need those hard rubber jack extenders to raise the trailer higher so both wheels on one side are clear. If I wasn't there to watch over them, something bad could have happened.
