07-21-2020, 11:39 AM
#21
2020 25' Globetrotter
Santa Rosa
Originally Posted by PB_NB
I could see 15 in the photo, but that was my first thought as well. When switching to 16" tires does the outside diameter stay the same as the 15's?
Airstream uses 225/75 series tires with both 15" and 16" wheels. The 225/75/16's have a larger overall diameter, greater circumference and fewer "revolutions per mile" than 225/75/15's.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
07-21-2020, 11:41 AM
#22
Oswego
16" wheels with 225 75s are about 1" larger diameter then 15s with the same aspect ratio.
-Rich-
07-21-2020, 12:40 PM
#23
Tampa
No.
The distance between tires will be reduced by 1". At the ground, it may be negligible.
07-21-2020, 01:41 PM
#24
1967 26' Overlander
Bugtussle
, Oklahoma
You pull the trailer over the levelers to remove them Watch this YouTube video starting a 1:10:
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
07-21-2020, 01:46 PM
#25
2018 27' Globetrotter
Apollo Beach
Originally Posted by dznf0g
Do you have dual axles with 16" tires and rims? That reduces the distance between the tires just enough to be a problem.
Yes, and mine work perfectly by driving over the top. You just need to go over it slowly and they just stand up on the fat end. And yes I do have 16" Michelins.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
07-21-2020, 03:54 PM
#26
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
On my 3 axle I use two "TrailerAid" ramps to change a tire. When finished, I just pull off very slowly. Never a problem.
guskmg
07-21-2020, 06:18 PM
#27
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland
16" Mich Lts are a bit larger in diameter, don't remember exactly how much. If given the room I just back up over the Andersons.
07-21-2020, 06:35 PM
#28
2019 22' Sport
Port Coquitlam
, British Columbia
16" idea makes sense and would only make the leveller more prone to getting stuck between the tires if the space is 1 inch less than the 15's.
If continue to drive in the same direction that you took when driving onto the levellers, would that allow the rear leveller to be rolled up between the tires making extraction easier? That's what the video demonstrated and it looks like it should work just fine unless the Airstream setup doesn't allow for this process.
Peter.
"Live Long and Prosper \\//" - Spock
07-21-2020, 06:49 PM
#29
Oswego
I have always rolled down off of them rather than over the top of them. One time while trying to get the full 4", I pulled up to far and set the park brake. When I got out the heel was at about 50 to 60* relative to the ground and the tip of the leveler was firmly stuck into the rear tire. If I had continued, I am sure I would have snapped it. So cutting an inch off was necessary in my case.
-Rich-
07-22-2020, 05:04 PM
#30
2019 22' Sport
Port Coquitlam
, British Columbia
I was so excited today when UPS delivered my leveller!
It looks pretty robust, I don't know how these could break.
The instruction sheet is very useful.
Peter.
07-26-2020, 10:03 AM
#31
Tom O
1966 17' Caravel
Altadena
I cut one of mine of per the directions. One of my best purchases. Sometimes they move when parking on gravel. A doormat under them works just fine.
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
CA-7
07-26-2020, 11:34 AM
#32
2008 27' International FB
Shoreacres
LEGO levellers
I use the LEGO style levelling blocks. Each block raises you about 1 inch.
07-26-2020, 12:09 PM
#33
2014 25' Flying Cloud
Comox
, British Columbia
Originally Posted by TravisH
Anderson says cut them off and that seems even worse as you lose the ~1" level.....
Any suggestions? This happens every time...
Trav
Either have a spotter to stop you just before it does that or cut off an inch.
Been using them for several years with an inch cut off and hundreds of nights on various surfaces and have never felt the loss of an inch of the leveller to be an issue.
07-26-2020, 02:32 PM
#34
Highlands Ranch
My trailer is a bit heavier than most of your trailers. (Still looking for that perfect AS though.) 11K GVWR. I have the Anderson Levelers and use them almost every trip. I haven't broken either of them.
For the leveler between the tires, lift the thick end up so it is between the tires, not by the ground. They did this within the first few seconds of the video.
I have 15" tires and the distance between the tires is a little tight. The leveler still fits if I get the angle just right.
I do not drive off my levelers. The trailer goes in the reverse direction from which the trailer was loaded onto the levelers. Simply driving off the levelers seems to be a good way to damage a tire, break the leveler or get it stuck.
My only complaint about the levelers is that they are too narrow. I would like to have a pair that are as wide or wider than the tire. The narrow width tends to sink into the ground too easily, necessitating a plank under them.
2006 Fleetwood Gearbox 220FB (toy hauler) <- current
2017 F-350 CCLB 6.7L
2019 Nissan Leaf SV+
07-26-2020, 06:18 PM
#35
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Andersen products are junk
07-26-2020, 06:19 PM
#36
1987 27' Sovereign
Calgary
, Alberta
levellers
You have too much time on your hands. How do you think your airstream stays stable when going over traffic calming measures or the odd girl scout who gets in the way? You either go over, under or around - in this case I vote to go over
07-27-2020, 05:41 AM
#37
2016 25' Flying Cloud
Selbyville
, Delaware
I’ve had my Andersons since I got my rig. When I upgraded to 16 inch wheels and tires I just cut mine down about 1.5 inches with my jigsaw. No issues at all now. Never have to drive over them. Oh and BTW, get the rubber mats for under the levelers on amazon and they won’t ever slip again when you are leveling. I wouldn’t s be without mine!
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel
WBCCI #9026 Delmarva Unit
07-27-2020, 06:26 AM
#38
Box Elder
, South Dakota
Thanks for the sense of humor!
07-27-2020, 12:28 PM
#39
2017 28' International
WAPPINGERS FALLS
, New York
Sometimes we back up to level or you can put the level in front of the first tire
07-27-2020, 12:59 PM
#40
2020 30' International
Whereweparkit
, Anywhere
If you have dual axles you should have a leveler under both tires on one side.
Jeremy
Full-timing it in a 2020 International Serenity 30RB!
https://AdventureToaster.com
TV: 2020 Ram 2500 Limited CCSB Hemi
