Old 07-12-2022, 11:38 AM   #1
2021 25' Flying Cloud
Woodbury , CT
Adding Solar Panels
I have a 2021 25'FC with the pre wired solar package installed. Can I now have the panels added to the roof and connect to the outlets there, or get a portable panel and hook it the the solar outlets near the propane tanks, and be on my way. Or is there other equipment I need to get in order to use the solar set up?
Thanks..........
stevegilmore is offline   Reply With Quote
Old 07-12-2022, 01:24 PM   #2
Dennis C's Avatar
Evergreen , Colorado
You’ll need a solar charge controller if you add panels to the roof.
Many portable panels (including Zamp) come with charge controllers and they can be plugged directly into the port. If I’m not mistaken, the polarity of Zamp panels is reversed compared to some other brands. The port on your Airstream is likely wired specifically for a Zamp portable panel. It’s something to be aware of, and potentially modify if you choose another brand.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Dennis C is offline   Reply With Quote
Adding two more Zamp solar panels to the roof Dennis C Generators & Solar Power 56 08-06-2022 07:50 AM
Adding solar panels to a B190 Kstills Generators & Solar Power 0 06-07-2022 06:49 AM
Adding solar panels that are not ZAMP Bullwinkle Base Camp 6 02-13-2018 01:05 PM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
Adding Solar Panels to a Safari 25' FB AronS Generators & Solar Power 24 05-29-2014 09:34 PM
