Old 01-17-2022, 02:17 PM   #1
Sebastopol , California
Absorption Refrigerator venting
Hello, My wife and I own a gutted 71 Tradewind. I am in the process of remodeling it and am now installing a new kitchen. The original layout had what was probably a 3 cu ft 2-way refrigerator next to the entry door. The original exhaust flu is still in place leading up to the roof vent. There is no lower side vent to the outside, but instead an 8x8 inch screened hole cut in the floor. Installation guides for every mid size absorption refrigerator I have found call for a lower side vent where the exterior access door is. Is it safe to install the refrigerator without the lower side vent but instead with an 8x8 floor vent? And if not, any thoughts on how to proceed? Thank you for your thoughts.
Lou P
LouP is offline   Reply With Quote
Old 01-17-2022, 02:51 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My previous Airstream was a 75 TradeWind with a the same configuration that you have. The only venting it had was in the floor and the exit up the chimney. The side door was solid with no venting. It sounds like you have the same setup.
Richard
Old 01-17-2022, 02:57 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
My guess is that they don't show the option to have venting from the floor because no modern trailers are set up this way. If I was to install a fridge in that space I'd keep the floor intake and just make sure that the overall dimensions of the air channel are correct. They shouldn't be too small, but be careful that they aren't too big either. You ultimately want the air to flow across the coils/fins in the proper place so that the heat is able to be shed to the passing airflow. Too large an air channel allows the airflow to bypass the coils/fins.
Richard
11018
richard5933 is offline   Reply With Quote
Old 01-17-2022, 03:06 PM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
[QUOTE=LouP;2570294]Hello, My wife and I own a gutted 71 Tradewind. I am in the process of remodeling it and am now installing a new kitchen. The original layout had what was probably a 3 cu ft 2-way refrigerator next to the entry door. The original exhaust flu is still in place leading up to the roof vent. There is no lower side vent to the outside, but instead an 8x8 inch screened hole cut in the floor. Installation guides for every mid size absorption refrigerator I have found call for a lower side vent where the exterior access door is. Is it safe to install the refrigerator without the lower side vent but instead with an 8x8 floor vent? And if not, any thoughts on how to proceed? Thank you for your thoughts.
Lou P[/QUOTE
The hole in the floor is how Airstream vented refrigerators until 1978 or so.
Regards,
John
Trnpk Crsr is offline   Reply With Quote
Old 01-17-2022, 03:58 PM   #5
2007 16' International CCD
Somewhere , Colorado
All good comments and advice above. I don’t think you have any issues/problems with the floor vent, as long as you be sure it is mouse proof.
In my opinion you are blessed with having the chimney and roof vent — unfortunately Airstream moved away from this on their smaller trailers — because it is key to effective flow of the air. The other key (and you will see specs in their installation manuals) is very little dead air space around the unit and only a couple of inches behind it.
field & stream is offline   Reply With Quote
Old 01-18-2022, 08:53 AM   #6
Thank you
Hey folks, Thank you very much for your quick and informative replies. They really helped me. I'm going to buy a new fridge today. Yea. Lou P
Old 01-18-2022, 11:30 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We had the hole in the floor for venting in our '72. Replaced it with solid floor, and then cut vent fins in the hatch behind the frig. Works fine for us. We screened the hatch, and have to vaccuum the screen off once in awhile to keep the air flow clear.
Kay
Old 01-18-2022, 12:54 PM   #8
2020 23' Flying Cloud
Sebastian , Florida
Kay (Minno) raises an excellent point about access for cleaning and maintenance.
Visible through the lower access door on our '20 FC is a black box (on the left side looking from behind) that contains electronics performing some essential function, but probably in a less failure proof way than Granddad's fridge. Allow for a removable side panel or a sliding track when you install.
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Dinosaur 3850712.01 main board for Dometic Absorption refrigerator. - Florida weismans Airstream Classifieds 2 09-12-2021 07:34 PM
Pros Cons Swapping Absorption for 12VDC Refrigerator Josephine517 Refrigerators 32 09-05-2021 01:13 PM
Investigation: absorption refrigerator fires waninae39 Refrigerators 0 07-11-2019 09:00 AM
Electric heating element for Norcold Absorption Refrigerator Carol in Air Refrigerators 3 08-21-2014 07:39 AM
New atwood gas/absorption fridge lewster Commercial Listings 17 02-25-2012 07:59 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
