Wheel well trim 1992 Excella
I'm replacing the metal trim on my curbside wheel well. It's a two part affair. This is a 29' 1992 dual axel Excella. The first piece of trim pinches the aluminum and the poly wheel well cover together around the wheel well arc. It is fastened on with pop rivets. The second piece mounts to the outside of the first piece with concealed screws and hides the exposed pop rivets. The first piece needed only to be trimmed to fit. The second piece is more complicated. It already has most of the needed curves (radius curves) to fit around the wheel well opening, but it requires additional radius curves to turn into the end on the wheel well ending up behind and Infront of the wheels.
My question is does anyone have experience with this and can you advise me on how you put bends into this trim. I can see it requires some crimping, but because of it's complex shape I'm not certain how to accomplish bending curves into it. I have a five blade hand crimp tool and that's it. What else do I need?
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
