Old 08-14-2018, 01:55 PM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Spring , Texas
White Roof - what is it?
What is the material on my 2015 FB FC? It is white - is this a coating over the aluminum? What is it made of??
Glenn
PSU1981 is offline   Reply With Quote
Old 08-14-2018, 02:18 PM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
The panels come white from the supplier to AS, several members have painted their vintage AS, it really cuts down on heat transfer as they have told. Use the main search up top to find several posts on this from late 2000's era when AS started using the white roof panels.
vintagemotor is offline   Reply With Quote
Old 08-14-2018, 02:25 PM   #3
PSU1981
PSU1981's Avatar
Spring , Texas
Thanks!!!
Old 08-14-2018, 02:36 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
On the Airstream website there is a document that tells the history of aluminum that has been used through the years.
This was what it said in 2009, the year the document was published:
3005*H18*Polar*White*.032*x*60"*Aluminum*3105*H14* from*Owens*Corning*
https://www.airstream.com/wp-content...92c0a731f5.pdf
Alan
Old 08-15-2018, 08:04 AM   #5
PSU1981
PSU1981's Avatar
Spring , Texas
Thanks!!!
Old 08-15-2018, 09:04 AM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Google something called "bus kote".
Old 08-15-2018, 09:27 AM   #7
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I applied 4 coats of "Bus Coat" this spring before we left on our summer trip.....amazing difference......outside temps were 90 to 97 degrees most of the trip. We have a single Duotherm Penguin, inside temps were maintained at 76 to 77 degrees....Prior to "Bus Coat" temps were 80 to 82 degrees in that sort of outside temperatures.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-15-2018, 09:42 AM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Good to great minds think alike Larry!
Are you guys off the road for the summer?
Old 08-16-2018, 06:28 AM   #9
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
We're back home, we were only gone about 2 months this year so far. Jacquie has an upcoming cataract operation later this month. Had a great trip through the midwest this year.....Going to Tennessee for a month or so in Sept/Oct....
How 'bout you guys?
Larry
Old 08-16-2018, 09:29 PM   #10
Lebanon , Tennessee
Larry
Did you only paint the roof white or the entire trailer, sides, front, back ,etc?
Rzrbrn is offline   Reply With Quote
Old 08-17-2018, 06:09 AM   #11
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Only the top panels that are already painted white. 1st coat is a special primer for Bus Coat, then follow with multiple coats of Bus Coat. Here's the link for the company.
http://www.hytechsales.com/prod2150.html
If you have questions, the sales reps at the company were very helpful to me..
Larry
Old 08-17-2018, 06:56 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I 're-covered' our 15yr old roof with Griot's carwash soap and green scrubby pads. 👍😳👍
ID:	320095   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire"
Amanamus
Tahawus....🌥
Paint Roof White trevisgardne Roof 31 08-05-2019 12:53 PM
Warm-white vs cold-white LED lights? aircampr Airstream Lifestyle 64 03-13-2015 04:31 PM
White Roof Sealant on Newer Airstream clancy_boy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 02-21-2007 06:32 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
White Paint for roof ? Davis Clearcoat, Exterior Paint & Trim 8 05-30-2004 03:35 PM
