Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 09-12-2010, 04:29 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Temp repair to hole from dent in roof.
I have to quater size holes from a dent in roof from falling tree limb the area is pretty bent up with small creases so a patch will not work it won't lie flush. Any good repair stuff like vulcan maybe ? suggestions. I do plan on replacing that area with new section but I need a temp seal for now .
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 09-12-2010, 04:38 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use that aluminum foil tape for smaller hole. Otherwise cut a patch from aluminum flashing put sealant(Vulkem or Sikaflex) under the edges and rivet or use small sheet metal screws around the side.
Aaron
WBCCI #XXXX AIR #2495
Nothing but a 14x25 hole in the roof nmeyer Roof Vents, Skylights & Fans 14 04-03-2021 01:28 PM
Another Roof Dent Question airtime Roof 6 09-15-2010 06:09 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
What is the best way to repair hole in frame toastie Repairing/Replacing Floor &/or Frame 2 04-08-2008 08:44 PM
cutting 14 x 14 hole in roof mwillis1970 Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-04-2005 09:36 AM
