Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Roof
Old 07-25-2019, 08:28 AM   #1
pastorwug's Avatar
2020 19' Caravel
SANTA MARIA , California
Rooftop strength?
I am adding a Micro-Air EasyStart 364 to our Rooftop A/C unit this week and am wondering if I can get up on the roof of our Bambi without damaging anything. I understand it's pretty strong and technicians do get on top of other Airstreams - how about the Sport 16?
2020 Caravel 19cb
Haven't arrived but well on our way!
KK6YFG
Central Coast of California
Calvary Chapel of Santa Maria
pastorwug is offline   Reply With Quote
Old 07-25-2019, 09:03 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Do not know about your trailer but where you see rivets, it is strong enough. Stay off end caps.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-25-2019, 09:17 AM   #3
1981 31' Excella II
New Market , Alabama
What Larry says. Not a bad idea to use a shelf board to distribute your weight if you step between the rivet lines. I installed an AC on my trailer without issue. We had a couple guys on the roof. As Larry said, the end caps have no ribs to support them. Make sure the roof is dry.
Perry
Old 07-25-2019, 09:18 AM   #4
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There's always an *if* .... I suspect there is a weight range that is ok and if you are significantly past that you need to be extra careful. If you are an "enhanced model" you likely are already aware of that
Tools and stuff for an easy start are not going to weigh much. If you ever are doing something where the "stuff" starts to get heavy, it also needs to be carefully positioned.
If you watch them play on the roof of a trailer at JC it's quite a dance. They do the "full OSHA" approach with a harness and safety rope going to the roof of the building. Stay safe
uncle_bob is offline   Reply With Quote
Old 07-26-2019, 02:26 PM   #5
Msherw's Avatar
2018 22' Sport
Blue Sky Ranch , Texas
Shelf board to kneel on would be a great idea. Else, find the rivets and only kneel on the ribs. Post your install via video or pics.
M!ke
2019 Tiffin Wayfarer 24TW
Ham Radio Call sign K5FT
Msherw is offline   Reply With Quote
Old 07-26-2019, 03:36 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I use 1/4" plywood squares to move around on my trailers roof.
CRH is offline   Reply With Quote
Old 07-26-2019, 06:06 PM   #7
batman's Avatar
1964 22' Safari
modesto , California
You can do this. Look at the sides of your trailer and follow the rivet lines from the sides up close to the middle of the top of the trailer. Those will be the ribs on the inside of the walls of the trailer. If you stay on or near the rivet line you should be fine. Me and an other guy 170 & 180 lbs have been all over my 64 Safari roof installing a new AC. Stay off the end caps and don't fall off.
Best of luck
-Dennis
batman is offline   Reply With Quote
Old 07-26-2019, 06:50 PM   #8
2007 27' International CCD FB
San Diego , California
Best way is a to watch someone do it. Great tips as well.
My preference is not to use an a-frame ladder, rather a leaning one set on some key drill rails on the window or door. Makes transferring much easier.
pteck is offline   Reply With Quote
Old 07-26-2019, 07:09 PM   #9
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
I'm a XXXl/ tall kinda guy. When working on the roof line, staying on the rivet lines and using 1/4 plywood to span the distance betweent rivet line is wisdom in words. It will save you thousands of dollars.
Tac GA-20
Air Forums 20320
KeithC is offline   Reply With Quote
Old 07-26-2019, 07:40 PM   #10
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I wrap a strip of carpet or even a rug around a plank. Make sure it is not slippery against the roof. If you have a 4' rug with rubber backing, use that with rubber backing out against the roof.
You have a tendency to want to put a knee between the rivets. You will leave a dent. Don't do that.
You need somewhat of a good balance. If you have problems with this, not good walking on the roof.
I use a regular ladder against the awning. The bottom of the ladder is roped to and around a tire. You don't want to lose your ladder when you step off onto the roof!
Go ahead and try. It's the only way you are going to learn.
Tom & Doty
turk123 is offline   Reply With Quote
Ford frame strength BillTex Tow Vehicles 25 04-30-2014 11:32 AM
Question on frame strength on 31' Sovereign hinz57 Airstream Trailer Forums 15 04-18-2009 07:17 PM
Rivet Grip Strength monocoque Ribs, Skins & Rivets 10 04-12-2008 09:58 PM
Ford Frame Strength--Pt. 2 Brad Hunt Tow Vehicles 3 10-24-2007 11:11 AM
Roof Strength Lee Davis Roof 3 09-04-2005 12:20 PM
