Old 04-07-2020, 06:40 PM   #1
1963 22' Safari
Bayside , California
Roof dent repair? '63 safari
Hi Folks, Has anyone been successful in repairing dents on the roof from pounding / pushing them out from the inside? I got my bathroom gutted and realized this may be the only time to try to repair my dented roof. See photos.
ID:	365141   Click image for larger version
Johnieappel is offline   Reply With Quote
Old 04-07-2020, 07:19 PM   #2
1966 22' Safari
Fredericksburg , Texas
You could probably push/roll the majority out, but the crease is another story. Since that’s a stretch formed panel, you may consider drilling out the rivets, removing the segment and finding someone with an English wheel to roll it out. Maybe those who have experienced this dent location will chime in. Good luck
Bubba L is offline   Reply With Quote
Old 04-07-2020, 10:58 PM   #3
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
If your inner cap is out, the super majority of that can roll out if you're careful and take your time, and of course have the right tool. Get in touch with Aerowood on here. He makes a nice aluminum roller that will help you carefully work that dent out. It'll never be perfect, but I was able to roll dents far worse, with deep creases out of a shell that actually blew off the frame in a wind storm (by previous owner) during a shell off and tumbled down the road. very careful rolling from inside and outside with some heat (a heat gun helps) and hours of work it'll be hardly visible.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 04-12-2020, 11:51 AM   #4
1963 22' Safari
success
I was able to get it pretty good so far. I'm sure if I were to polish it you'd see the remaining imperfections. Dealing with the fiberglass ceiling end cap was as much of a challenge!
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Another Roof Dent Question airtime Roof 6 09-15-2010 06:09 PM
Temp repair to hole from dent in roof. Mrcrowley Roof 1 09-12-2010 04:38 AM
Dent repair - '97 Safari 25' 25Safari_97 Ribs, Skins & Rivets 1 09-01-2009 09:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
