Old 07-01-2020, 08:28 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Roof Coating, Which do I do first?
I think I know the answer to this question, but rather than hope I'm right I thought it best to ask. I want to apply some kind of Cool Coat to the roof of my 29' Excella. Naturally the roof will be cleaned and scuffed before I paint it. At this point I have not selected the finish I will use. My logic says I should install any an all items that need to be sealed, including maxxair fans, the AC, possibly the antennas, etc. first.
Here is my question: Should I apply the primer and the heat reducing finish before or after I install the AC, Roof Vents, etc.?
I hope I've stated this clearly.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 07-01-2020, 09:28 PM   #2
1972 23' Safari
Middletown , Rhode Island
I would install, seal all fans, ac, antennas before coating the roof. I'm doing the same thing, just added another maxxair fan, solar panel brackets, combiner box, sikaflexed them, added all my cable tie mounts, just need to finish polishing up my AS and then I'm going to seal kote my roof as well.
Mx468 is offline   Reply With Quote
Old 07-02-2020, 06:07 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
You need a clean, dry surface for whatever sealer you use to bond properly.
Obrigado, é hora de descansar.
Tahawus
Old 07-02-2020, 06:22 AM   #4
2010 25' FB Flying Cloud
Davenport , Iowa
while you are at it; place a piece of 2X2 between the roof and inner shell. this will give more support to the fan and skylight and reduce any vibrations.. do this in the space away from the rib. This was suggested by a AS service tech. I had it done when I coated my roof. The 2 by should be about 2 inches bigger than the opening.
Airtandem is online now   Reply With Quote
Old 07-08-2020, 07:30 AM   #5
Re-Pete's Avatar
1992 29' Excella
Mx468,
Thanks, How are you mounting your solar panel brackets? I've seen some folks using 3M VBH tape instead of screws, Thoughts?
Pete
Virginia Beach, VA
Old 07-08-2020, 07:38 AM   #6
Re-Pete's Avatar
1992 29' Excella
Originally Posted by ROBERT CROSS View Post
X2
ROBERT CROSS,
Makes sense.
Airtandem,
Good suggestion, I'm actually planning to add some angled aluminum or similar for that very purpose.
Pete
Virginia Beach, VA
Old 07-08-2020, 08:01 AM   #7
Pete,
I used 3m 3" Extreme Sealing Tape over all the areas that had to be caulked...8+years SFSG.
Tahawus
Roof Coating/Sealing using NovaTuff RC-100 Flexible Epoxy Roof Coating sgschwend Clearcoat, Exterior Paint & Trim 3 10-08-2016 10:11 PM
Do you have rubber coating on the roof? dbtolman Roof 22 03-16-2009 04:29 PM
Removing black roof coating lessen Cleaning, Stripping & Polishing 1 06-02-2006 09:55 AM
removing roof coating airtim Cleaning, Stripping & Polishing 2 04-02-2005 09:43 PM
Roof coating FrankR Roof 4 07-22-2002 01:56 PM
