Old 05-26-2022, 10:47 AM   #1
Steamgauge
1966 24' Tradewind
Bonney Lake , Washington
Preping for A/C on '66 Tradewind
I am going to put A/C on my '66 Tradewind project. Do I have to remove the entire vent assembly? '66 was the first year the roof came reinforced from the factory to accept A/C so there is no structural work that need to be done.
steamgauge is offline   Reply With Quote
Old 05-26-2022, 06:49 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello: I should think you will be removing the entire old vent/fan assembly so the new AC will fit through the whole. The AC takes a dedicated 20 amp circuit from the breaker box to the AC. I bet you 66 has that wire already run up there, and maybe you have found it.
Here is a photo of the factory installed wire rolled up on the top right of the breaker box. My 66 Trade Wind had a separate breaker for the AC, but I don't know how the wire was run. I never took the AC off.
David
Name:	1708 Sale Rear Shade-800x600.JPG
ID:	416550   Click image for larger version
Name:	1404 Electrical New Breaker Box 2 (Small).jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 05-26-2022, 07:13 PM   #3
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
San Marcos , Texas
Images: 38
Send a message via AIM to kevinkatz
the hole has to be 14x14 maybe a 1/4" more. so it all depends on what the vent looks like but i would suspect it comes out. i put c channel around that to increase stability.
kevinkatz is offline   Reply With Quote
1959 Airstream Tradewind :: 1959 Airstream Tradewind steveirving Airstream Registry Discussions 1 07-27-2021 06:15 PM
"Firefly" 1960 Tradewind :: 1960 Airstream Tradewind 2vets Airstream Registry Discussions 0 08-19-2011 08:30 AM
will a '67 Tradewind door fit a '62 Tradewind? scoxx30 Doors & Locks 4 11-21-2005 11:58 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
