Old 05-06-2020, 10:05 PM   #1
AdvToaster's Avatar
2020 30' International
Whereweparkit , Anywhere
I know white cap
Anyone have any idea what this is on the roof of my new 2020 IS 30RB?
Maybe a pre-wire for something? Looks like the wifi logo on there.
Edit: Argh, iPhone. The title should be “Unknown white cap”.
Jeremy
Soon to be full-timing, got the TV, got the trailer, installing the solar!
https://AdventureToaster.com
AdvToaster is offline   Reply With Quote
Old 05-06-2020, 10:11 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It’s the Wifi antenna for the Fusion radio
Old 05-06-2020, 10:16 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Looks to be an antenna for SiriusXM satalite radio?
wulfraat is offline   Reply With Quote
Old 05-06-2020, 10:27 PM   #4
AdvToaster's Avatar
Now that hat you mention it that is slightly reminiscent of the SiriusXM logo, but I’d expect they wouldn’t miss an opportunity to put their full name on something, and unfortunately the new JL Audio MM50 head unit they’re installing in the International doesn’t have satellite radio.
Jeremy
Old 05-06-2020, 10:43 PM   #5
AdvToaster's Avatar
I’ve got the JL, not Furrion. No WiFi on my radio. Maybe they screwed up and installed it on the wrong trailer!
Jeremy
Old 05-07-2020, 09:28 AM   #6
1964 30' Sovereign
Ione , CA
I concur with the antenna comments. But I believe an aluminum or plastic collar should have been mounted around it that would cover the putty/silicon they used. Sort of messy the way they did it. You could make your own collar out of aluminum by drilling a center hole to fit over the center piece. Drill and mount rivets in a circle to secure. Would look a lot nicer if aesthetics are important...
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
Trowbridge is offline   Reply With Quote
Old 05-07-2020, 10:36 AM   #7
2015 25' Flying Cloud
Bettendorf , Iowa
I would be concerned about it collecting water if it is on your roof.
I would check with your dealer and have them correct it at it looks like a mistake.
Rltports is offline   Reply With Quote
Old 05-07-2020, 10:47 AM   #8
AdvToaster's Avatar
I'm really not concerned about water on it or appearance (it's on the roof, you can't see it). I just want to confirm what its doing on my trailer before I put a solar panel on top of it.
Jeremy
Old 05-08-2020, 01:53 PM   #9
1988 32' Excella
Robbinsville , New Jersey
Could that be the antenna for the AS connect system?
Old 05-08-2020, 02:14 PM   #10
Mollysdad's Avatar
The orientation makes the image look recessed. How about this?
Old 05-08-2020, 02:37 PM   #11
AdvToaster's Avatar
That is in fact the correct orientation. Thanks!
It's right next to the fantastic fan if that helps anyone.
Jeremy
Old 05-11-2020, 08:00 AM   #12
AdvToaster's Avatar
SoI think it's the AM/FM antenna, though I think it's awfully short for that. There's no tall antenna for the radio on mine like previous year AS's have had.
Jeremy
Old 05-11-2020, 09:38 AM   #13
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
If it is an antenna of some sort, which appears to be the case, are you risking losing reception to whatever it is connected to if you cover it with a solar panel? Just a thought.
thewarden is offline   Reply With Quote
Old 05-13-2020, 10:02 AM   #14
Napa , California
What is located beneath that device on your trailer? It might give a clue as to function.
Big Vic is offline   Reply With Quote
Old 05-13-2020, 10:10 AM   #15
AdvToaster's Avatar
Nothing, just empty ceiling space.
Jeremy
LED Color correction with filters, from cold blue-white to warm-white Bob Blarney Lights - Interior & Exterior 0 05-29-2019 08:08 PM
Pickup truck cap or no cap? weber.roger Airstream Lifestyle 28 12-04-2015 06:22 AM
anyone know what these white things are? Craig Interior Restoration Forum 6 07-27-2015 05:20 PM
Warm-white vs cold-white LED lights? aircampr Airstream Lifestyle 64 03-13-2015 04:31 PM
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
