05-06-2020, 10:05 PM
2020 30' International
Whereweparkit
, Anywhere
I know white cap
Anyone have any idea what this is on the roof of my new 2020 IS 30RB?
Maybe a pre-wire for something? Looks like the wifi logo on there.
Edit: Argh, iPhone. The title should be “Unknown white cap”.
Jeremy
Full-timing it in a 2020 International Serenity 30RB!
https://AdventureToaster.com
TV: 2020 Ram 2500 Limited CCSB Hemi
05-06-2020, 10:11 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
It’s the Wifi antenna for the Fusion radio
05-06-2020, 10:16 PM
2017 30' International
Broomfield
Looks to be an antenna for SiriusXM satalite radio?
05-06-2020, 10:27 PM
Whereweparkit
, Anywhere
Now that hat you mention it that is slightly reminiscent of the SiriusXM logo, but I’d expect they wouldn’t miss an opportunity to put their full name on something, and unfortunately the new JL Audio MM50 head unit they’re installing in the International doesn’t have satellite radio.
Jeremy
05-06-2020, 10:43 PM
Whereweparkit
, Anywhere
I’ve got the JL, not Furrion. No WiFi on my radio. Maybe they screwed up and installed it on the wrong trailer!
Jeremy
05-07-2020, 09:28 AM
1964 30' Sovereign
Ione
, CA
I concur with the antenna comments. But I believe an aluminum or plastic collar should have been mounted around it that would cover the putty/silicon they used. Sort of messy the way they did it. You could make your own collar out of aluminum by drilling a center hole to fit over the center piece. Drill and mount rivets in a circle to secure. Would look a lot nicer if aesthetics are important...
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
05-07-2020, 10:36 AM
2015 25' Flying Cloud
Bettendorf
, Iowa
I would be concerned about it collecting water if it is on your roof.
I would check with your dealer and have them correct it at it looks like a mistake.
05-07-2020, 10:47 AM
Whereweparkit
, Anywhere
I'm really not concerned about water on it or appearance (it's on the roof, you can't see it). I just want to confirm what its doing on my trailer before I put a solar panel on top of it.
Jeremy
05-08-2020, 01:53 PM
1988 32' Excella
Robbinsville
, New Jersey
Could that be the antenna for the AS connect system?
05-08-2020, 02:14 PM
Tampa
The orientation makes the image look recessed. How about this?
05-08-2020, 02:37 PM
Whereweparkit
, Anywhere
That is in fact the correct orientation. Thanks!
It's right next to the fantastic fan if that helps anyone.
Jeremy
05-11-2020, 08:00 AM
Whereweparkit
, Anywhere
SoI think it's the AM/FM antenna, though I think it's awfully short for that. There's no tall antenna for the radio on mine like previous year AS's have had.
Jeremy
05-11-2020, 09:38 AM
2016 27' International
Sherwood Park
, Alberta
If it is an antenna of some sort, which appears to be the case, are you risking losing reception to whatever it is connected to if you cover it with a solar panel? Just a thought.
05-13-2020, 10:02 AM
Napa
What is located beneath that device on your trailer? It might give a clue as to function.
05-13-2020, 10:10 AM
Whereweparkit
, Anywhere
Nothing, just empty ceiling space.
Jeremy
01-05-2021, 01:47 PM
2019 27' Globetrotter
2021 20' Basecamp
Verona
, Wisconsin
did you ever figure it out?
I'm looking at the same thing on my Basecamp 20X, but I have no radio or other antenna/electronics, so all of the suggestion for that make no sense for my Basecamp. Did you ever determine what it was?
01-05-2021, 02:27 PM
2015 20' Flying Cloud
Kingsport
, Tennessee
The logo on it looks like a cellular signal logo....
-Leslie
WBCCI #1051
01-06-2021, 08:33 AM
Whereweparkit
, Anywhere
I did not. It’s been covered by a solar panel since April and I haven’t worried about it.
My best guess is that it’s a port for the Airstream Connected antenna. They’ve probably pre-run wiring in the newer trailers for it.
Jeremy
