Old 03-14-2018, 09:04 AM   #1
2004 19' Bambi
2010 23' FB Flying Cloud
Bridger-Teton , Wyoming
Help! Frustrating Roof leak around A/C
I have been on top of my 2004 Airstream Bambi 3 times trying to seal it to keep water out to eliminate this link. I sealed EVERYTHING that had been sealed in the past and then the front and rear seams before the roof curves down. I used EternaBond around the Fantastic Fans and the A/C. And then an entire tube of Dicor around the seams of the EternaBond. I then used more Dicor around everything else like vent pipes and bathroom fan, etc. I have sealed everything...or at least I thought. Well, yesterday I walked out to the Airstream after it rained and sure enough, the leak was still there. It's coming out of the A/C.
What am I missing?!?
veg hed is offline   Reply With Quote
Old 03-14-2018, 09:21 AM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Have you checked the bolts that hold the A/C unit in place. Remove the inner panel and you will see 3 or 4 nuts that hold the unit on the roof. If I remember correctly, they should be tightened to 5 ft/lb. I have had to tighten mine a couple of times to stop a leak. Good luck!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 03-14-2018, 09:56 AM   #3
2007 22' International CCD
Make sure the gasket is intact, and thick enough. Some installs take a stack of two gaskets, and sometimes one gets left out. The roof curve can be a challenge getting a good seal if gasket is not thick enough or not compressed properly
Old 07-06-2018, 10:54 AM   #4
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Did this get resolved??
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Frustrating lack of information on equipment used in new AS Bruce B Electrical - Systems, Generators, Batteries & Solar 28 08-11-2013 11:44 PM
Fruitful but frustrating day AWCHIEF Off Topic Forum 2 01-21-2012 07:42 PM
Frustrating door leaks BayouFishin Doors & Locks 1 02-11-2010 01:13 PM
Frustrating leak from Fantastic Fan alteration AirHeadsRus Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 11-25-2009 04:36 PM
Helpful feature is frustrating pamelake Forum Admin, News and Member Account Info 9 03-13-2006 12:03 PM
