03-21-2020, 08:41 AM
Thurmont
, Maryland
Get rid of skylight
Has anyone ever gotten rid of the skylight? Not just replaced/repaired/recaulked.
I really hate the light. I keep it covered all the time. It is leaking. It needs repair, but I just want it gone.
Is it reasonable to replace it with aluminum on the roof and something else on the inside? Have any of you ever done something like this?
03-21-2020, 08:51 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
You could build an Aluminum lid “pan” with 1 1/2” lips and replace the skylight with that. Then use some insulation inside followed by covering the hole with a new piece of Aluminum skin. That should hide it well.
If it were me and I wanted to “hide” the skylight I would replace it with a Maxim Skylight and then just cover the inside with a new piece of Aluminum. That way it could be removed if you changed your mind later or sold the unit.
03-21-2020, 09:02 AM
1995 25' Excella
xxxxx
, xxxxxx
I just replaced my skylight. I used the original OEM. It is made by Sun-Tek. Home Depot can order them for $72. I did not replace it using the screws that go down through the skylight and curb the way it came from Airstream because as we all know the skylight will eventually crack and leak....Instead, I made 4 spacers and attached it with 4 screws going vertically into the side of the curb. I used VHB tape to seal the skylight to the curb flange..
..Had I wanted to block all the light, I could have just painted the underside black before the install.
03-21-2020, 10:46 AM
Thurmont
, Maryland
Thanks CRH. But would painting it black make it more likely to crack in the heat?
03-21-2020, 10:58 AM
2013 31' Classic
billings
, Montana
Our 13 31 Classic has 2 skylights....no problems with either one...they are held in place with double sided tape....on screws....no cracks..
03-21-2020, 11:00 AM
1995 25' Excella
xxxxx
, xxxxxx
Badagle,
You would just be painting the flat part that you see when you look up. I wouldn't think it would get any hotter than not painted.
03-21-2020, 11:02 AM
1995 25' Excella
xxxxx
, xxxxxx
I used the 4 screws going in horizontally as a belt and suspenders approach in case the VHB decided to let go going down the road.
Yeah, I meant to say horizontally in my first post...lol
03-22-2020, 10:19 AM
2004 30' Classic
Johnson City
Agree. If you get the Maxim Skylight with the dark gray tint, you will greatly reduce light. You could paint the Lexan outer pane for near complete opacity.
Our Maxim skylights are super - and fully weather tight. This is a much simpler and less expensive alternative to closing the opening.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
03-22-2020, 12:08 PM
1988 32' Excella
Robbinsville
, New Jersey
A couple years ago Del Gurney posted about replacing the skylight with a marine hatch. This was to block light and allow roof access from inside trailer.
https://www.airforums.com/forums/f47...tch-97128.html
03-22-2020, 12:18 PM
1964 26' Overlander
1964 19' Globetrotter
OlyPen
We got rid of the astrodomes on our 1964's (large skylight) as they leaked, cracked, etc and so did the direct replacements we tried out. Our final solution was to have a local window shop made a fixed skylight that we installed over the opening. The old astrodomes opened and our replaces don't but that has been a non-issue s there are other roof vents - we have plenty of airflow. The high r-value skylights have worked well, letting in filtered light and sealing up the big hole..
03-22-2020, 01:34 PM
2016 28' International
Trois-Rivieres
, Quebec
Putting in Maxims
As soon as the weather allows, I'll be replacing the OEM skylights (one cracked, patched with Gorilla tape) with a pair of Maxims. Much better design and material.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
03-22-2020, 02:01 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
If it is the standard 14” hole why not put a 70s’ style roof vent with a solid aluminum cap?
03-22-2020, 07:32 PM
1995 25' Excella
xxxxx
, xxxxxx
It's not a standard 14" hole
03-24-2020, 07:36 AM
1964 26' Overlander
Morganton
, Georgia
Details?
This sounds like a great solution for our 1964 leaky astrodome. Can you pm me with details, pics perhaps?
Lynn
03-24-2020, 10:40 AM
1964 26' Overlander
OlyPen
Lynn
Hi Lynn - you'll need to go up on the roof and measure the opening. Have a skylight made that will cover around the hole perimeter. The skylight sits on top of the trailer roof - not into the hole. The ones we had made stand proud of the roof about 2 inches and you can choose the frame color - they are aluminum but you can get them in anodized colors, if desired.
On the inside, we removed the lifters, leaving the channel in place. You can just leave it that way, or fit the channel with some reversed U channel to fill the gap, or perhaps some nice wood. On the overlander we just left the channel - it's OK -ish but looks unfinished. On the glove trotter we actually made a picture frame sort of thing to fill cover up the channel - will try to take some pics later today - but it's pouring outside just now...
03-29-2020, 05:21 PM
2016 30' Classic
Millersburg
, Michigan
Skylight solutions
We replaced ours with another Fantastic vent fan. They do not let in nearly as much light and provide more air circulation. Win win situation. The factory tech did a great job.
03-29-2020, 06:56 PM
1961 22' Safari
Union
, Oregon
I removed the skylight in my '61 Safari and covered the hole with a 24" by 24" square of aluminum. I then covered the inside hole with a home built 20" by 20" light fixture using LED's for the light. I like it very much and have light only when I want it.
Sam
04-05-2020, 11:34 AM
2008 25' Safari FB SE
Allen
I replaced mine with a flat piece of plexi 1/2" oversized the piece by about 6". The outer dome had cracked and started leaking. To much direct sunlight. Now even with the new piece I keep it covered. It sits in my back yard.
