I know, I know, another roof leak problem!!
Hi Airstreamers
Have any of you had a water leak at front section of trailer just to the left of the center area of the front window!!
2yrs ago I had it pressure tested at local rv place.
But couldn't find it!!
Perhaps you had a 34' classic with a similar water leak problem?
I have. I found it was the battery box hinge rivets. They are ordinary pop rivets. They are outside the seal. Rain runs down the inside of the frame and goes through the rivet head. Had the same issue on the rear side storage compartments. A little Capt. Tolleys on each rivet took care of the problem.
