Old 05-13-2017, 06:25 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Checking the Roof
I have never been on the roof of my 2009 Int. I don't have any leaks but I've had it for two years now and was curious if I should climb up there and check the sealant around vents etc.
Is this a good practice and how often should it be done? Can you actually get on the roof with out causing damage?
Thanks for any suggestions.
Hans627 is online now   Reply With Quote
Old 05-13-2017, 06:31 PM   #2
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I weigh 155 lbs ....
If get up there twice a year and check everything out and wash etc
I know where the frame is and where to walk and am very careful and take my time
If I were "heavy" I think I'd be more nervous
Probably many should not get up there arguably?
If a person steps off the write place and into the wrong - doing so would be very easy - could do some real damage
PharmGeek is offline   Reply With Quote
Old 05-13-2017, 06:33 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Absolutely the roof should be regulary inspected. Try to stay on the rivet lines and off the end caps.
MICHAEL
Old 05-13-2017, 08:21 PM   #4
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
You can lean a padded ladder on the side and get to most of the roof area. If you do go up, keep all weight (knees/hands) on rivet lines and wear shoes that will NOT slip.
Now, here is one I learned the hard way...DO NOT lean any weight on your very brittle A/C cover or your hand could go right through it....
Having said that, I go up yearly and take a spray wax with me and clean off any dirt/mold and wax at the same time while inspecting sealants around everything. Did I mention not to lean on the A/C vent at all...It looks so tempting to just lean for a second or two, don't do it. The A/C vent cover gets very brittle from the sun.
I actually have to seal my refrigerator vent cover tomorrow and will seal the heat shield while I am motivated. Two good places you should inspect! This job will be done from a ladder, not the roof. Easy to access from the side and I work better when standing than kneeling.
Some people have built a carpeted board that links between rivet lines (frame supports). That sounds good for the knees, but I have not put one together yet.
Good luck and remember to take all your tools/sealants with you the first time
malinois38 is offline   Reply With Quote
Old 05-13-2017, 08:48 PM   #5
2015 30' FB FC Bunk
Ayer , Massachusetts
Any issues with walking on a ducted air model?
Ted S. is offline   Reply With Quote
Old 05-13-2017, 09:07 PM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I had that same question in another thread
I was told it is the same concerns
Old 05-14-2017, 06:09 AM   #7
brokeboater's Avatar
2013 25' Flying Cloud
Crystal River , Florida
When I bought my first Airstream I treated myself to a 12' fiberglass step ladder. It was one of my smartest moves. I can get to most anything on an Airstream roof from that ladder without leaning anything, padded or not, on the Airstream. That said, I weigh about 215#, BAN, and have no problem walking on the roof as long as I stick to the rivet lines that have a frame member under them. I removed and reinstalled my air conditioner unit while walking around up there with no damage. I'm pretty sure there are a couple of rivet lines running for and aft, and maybe one or two athwart, that have no supporting member under them. Don't go anywhere near an end cap. Once one of those is rumpled, it's always rumpled. End caps are the most dangerous spot to work around.
brokeboater is offline   Reply With Quote
Old 05-14-2017, 06:25 AM   #8
Ruffn It's Avatar
2012 25' FB Flying Cloud
Huntersville , North Carolina
Like walking in an attic - put a board down that spans the width of the rivet lines and you'll have even less worry. As long as you don't let the board slip and scratch the clear coat on the way up / down etc.
Also:
Kevin & Deb & {Bella}
"To sit with a dog on a hillside on a glorious afternoon is to be back in Eden, where doing nothing was not boring -- it was peace." M. Kundera
Ruffn It is offline   Reply With Quote
Roof checking for leaks 1Boyscout General Repair Forum 2 03-21-2015 06:02 AM
Bambi 19'CCD goes in production 7/29, I'm checking my list! Rhodie Our Community 11 07-28-2004 07:21 PM
Checking water in the battery... drboyd Electrical - Systems, Generators, Batteries & Solar 1 08-15-2003 09:37 PM
Checking in time 53flyingcloud Our Community 7 04-02-2003 01:14 PM
Checking the Anode Rod... ALANSD Water Heaters, Filters & Pumps 1 05-08-2002 08:23 AM
