Old 03-25-2021, 10:50 AM   #1
2019 27' Tommy Bahama
Williamsburg , Virginia
Bumper compartment lid
We have a 2018 TT 27 foot and have experienced repeated problems with the bumper lid rubber cover peeling off. It’s the gray rubber that says Airstream, see pic during warranty we had the factory try to fix it within a year it was coming off again.Any ideas out there? Thanks
RichardBoyd is offline   Reply With Quote
Old 03-25-2021, 07:57 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Maybe some clear silicon will keep it down? Or silkaflex?
wulfraat is offline   Reply With Quote
Old 03-25-2021, 08:04 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Replace it with one from Aqua Marine deck. I’ve had them for years without issue.
ID:	391606   Click image for larger version
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 06-08-2021, 12:29 PM   #4
2004 25' International CCD
2012 25' International
slaton , Texas
did you fix that rubber
Hi, i have the same prob on my '19, T.B. 27'. The rubber logo mat is pulling up from all sides, i would like to re-glue it.
purchased from orig owner and AS informed her it was a factory mess-up??
Did you find a suitable glue / solution for your mat? i would like to fix mine, but i'm sure that a special glue or epoxy is needed. apparently AS did not use a suitable product to correct the problem. Do you know what they used?
appreciate any help,
thanks!!
gregg
gnowlin is offline   Reply With Quote
Old 06-08-2021, 01:44 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Try Gorilla Glue's Heavy Duty Construction Adhesive found at hardware store everywhere.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 06-09-2021, 07:41 AM   #6
slaton , Texas
Thanks! ill try the gorilla glue .
gregg
Old 06-09-2021, 09:21 AM   #7
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
I did the same. And they work great.
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 06-11-2021, 11:46 AM   #8
slaton , Texas
Thank you!!!
Will give it a try
Gregg
Old 10-18-2022, 02:41 PM   #9
2020 27' International
Neptune Beach , Florida
How did you get the perfect size? It looks great!
NN
NascarNomads is offline   Reply With Quote
Old 10-18-2022, 03:02 PM   #10
Saluda372's Avatar
2021 20' Caravel
Plaistow , New Hampshire
Does that Gorilla glue expand while drying ?
Learning and enjoying as we go !
Saluda372 is offline   Reply With Quote
Old 10-18-2022, 03:54 PM   #11
SlowPokePete's Avatar
2020 25' Globetrotter
Hillsdale , New York
It does, and is almost a little foamy in my experience.
I think if I were going to use gorilla glue, I would get a piece of wood that covers it length and width-wise and clamp it down, or place bricks or something heavy all along it to limit the expansion of the glue.
SPP
SlowPokePete is offline   Reply With Quote
Old 10-19-2022, 04:26 AM   #12
Saluda372's Avatar
2021 20' Caravel
Good stuff but I dislike the fact it expands.
Old 10-19-2022, 05:35 AM   #13
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Not sure if the Gorilla Glue you are talking about is the same stuff that woodworkers use, but when I had my wood shop we did some testing with the stuff and found that it was not nearly as strong as other adhesives out there.
The foaming action helps Gorilla Glue bond across small gaps, but it also causes a weaker joint. There are other adhesives out there which are non-foaming and have higher strength.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 10-19-2022, 07:40 AM   #14
1988 32' Excella
Robbinsville , New Jersey
I would probably glue it down or use 3M tape and add some rivets with stainless steel washers. It's not remotely close to being a water tight area.
Old 06-02-2023, 03:42 PM   #15
ts8501's Avatar
2022 25' International
NEW PRAGUE , Minnesota
I love the looks of your bumper upgrade/fix, but I cannot find this specific deck on the Aqua Marine Deck website. I think this fix would look much better than any additional glue or adhesive trying to fix the OEM Airstream deck. Any help in finding this solution would be much appreciated!
https://www.aquamarinedeck.com
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
ts8501 is offline   Reply With Quote
Old 02-10-2025, 01:15 PM   #16
2023 27' International
Banner Elk , North Carolina
May I ask what you ordered and in what measurements? So many pads on the website and don’t see yours. Thanks.
Babycake is offline   Reply With Quote
Old 02-10-2025, 01:16 PM   #17
I’m watching this. Couldn’t find it on the site either.
1987 Sovereign Bumper Compartment Lid Latch JohnBarth Bumpers & Bumper Storage 0 07-03-2020 10:56 AM
2015 30 FC - Battery Compartment Lid stuck andyvignes General Repair Forum 3 03-02-2019 05:54 AM
Lid of compartment over propane tanks hawksbil Base Camp 2 05-05-2018 09:42 AM
'79 rear bumper lid and compartment improvement? blickcd Bumpers & Bumper Storage 9 08-03-2017 08:08 PM
Help With Lid on 1963 Bumper Locker? utee94 Ribs, Skins & Rivets 31 04-14-2009 12:46 PM
