Old 11-04-2022, 08:47 AM   #1
2014 25' FB Eddie Bauer
Glen Arbor , Michigan
Washer with rubber for belly pan rivet?
Using a stainless metal washer with a bonded rubber side between the rivet and the pan seems to be a reasonable way to fix belly pan rivets which have pulled through the aluminum. Anything I am missing?
Wanna EB is offline   Reply With Quote
Old 11-04-2022, 09:05 AM   #2
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
That should work. If the frame you are riveting to is rusted out you may have to drill some new holes or the rivet might pull right out of the old hole..
Dingo Girl is offline   Reply With Quote
Old 11-04-2022, 12:22 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
My AS belly pan isn't aluminum.
I'd probably go with a oversized all metal washer and a rivet.
CRH is offline   Reply With Quote
Old 11-04-2022, 12:27 PM   #4
dznf0g's Avatar
Oswego , Illinois
I have been patching the area with about a 2x2 piece of heavier aluminum and re-riveting with a large head rivet.
-Rich-
Old 11-04-2022, 12:29 PM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
You can get large flange aluminum rivets. I've used lots of them to re-rivet the belly pan - with 1/2 flanges they'll usually do the trick. On a couple with even larger tear-outs, I cut small circles from aluminum bar stock to use as large rivet washers.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 11-04-2022, 01:12 PM   #6
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
You can also use a piece of plastic freezer bag to separate the Stainless Steel from the Aluminum, although an oversized steel rivet will work , it’s stronger than an Aluminum rivet.
Spelling edit
Silvr_Bullet is offline   Reply With Quote
Old 11-04-2022, 02:59 PM   #7
Great suggestions...thank you. I have already gone to the larger rivets which are now pulling through. I like the idea of a new piece of aluminum. I have a few of the rubber lined washers installed and will report their performance.
Tuck the side belly wrap under the flat belly pan or the other way around? haaseome Belly Pans & Banana Wraps 4 08-24-2021 11:34 AM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Belly Pan re-rivet. argosyman Belly Pans & Banana Wraps 11 04-15-2012 12:47 PM
what size rivet for U channel, skin and belly pan connection? benWa Ribs, Skins & Rivets 5 09-22-2009 08:49 PM
Belly Pan Rivet question Gregg S Ribs, Skins & Rivets 1 09-01-2009 08:30 PM
