Old 08-21-2021, 04:15 PM   #1
1972 Argosy 24
Philomath , OR
Tuck the side belly wrap under the flat belly pan or the other way around?
Putting my 1972 Argosy back together. I'm onto the belly pan and the side belly wrap next. Does the wrap tuck under the belly pan or does the belly pan tuck under the wrap? I've seen it done both ways and saw a thread that said the factory installed with the side wraps tucking under the belly pan. Seems to me that logically one would do the opposite, so that when water runs down the side of the trailer it doesn't run into the belly pan. In other words, you have a 3 part sandwich consisting of the frame rail the side wrap and the belly pan. Obviously the frame rail is the top slice of bread. Is the bottom slice of bread the belly pan or the side wrap? In other other words, either the belly pan or the wrap is the slice of cheese in between the two slices of bread. Which one is it? Sorry, if that made it even more confusing, haha. Thanks!
haaseome is offline   Reply With Quote
Old 08-21-2021, 04:22 PM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Originally Posted by haaseome View Post
.........Seems to me that logically one would do the opposite, so that when water runs down the side of the trailer it doesn't run into the belly pan..........Thanks!
And yet, that is exactly how the factory did it for several years in the early 70's. The worst part is, they didn't even use Vulkem or any other type of sealant to attempt to keep water out. It's a mess.
I caulked mine the best I could, but water still gets in with all that flexing, etc, as you drive.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 08-21-2021, 04:58 PM   #3
1988 32' Excella
Robbinsville , New Jersey
And this is why the fiberglass insulation in the belly is a bad idea. It works great as a sponge to hold water to rot the frame, if that's what you want.
Wazbro is online now   Reply With Quote
Old 08-23-2021, 08:20 PM   #4
1972 Argosy 24
Philomath , OR
Ok, that's what I thought. I think I'll be bold and do the opposite of the original and reinstall with the belly pan sandwiched in between the frame rail and the side wrap. Why not? Thanks for the help!
Old 08-24-2021, 11:34 AM   #5
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Wrapping the belly pan over the banana wraps (like the factory did) will make it easier to remove the flat belly pan in the future if you need access below the floor. The more overlap - the less water will enter horizontally.
Shari
RMVAC | ACI - CO (CAC) Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Belly Pan and Side Wrap Questions Re-Pete Belly Pans & Banana Wraps 12 06-21-2019 10:10 PM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Folding tuck-away table from 2013 Flying Cloud 2015fc23 Airstream Classifieds 0 11-27-2017 04:39 PM
Belly Pan & Banana Wrap Removal IronGiant Belly Pans & Banana Wraps 2 06-06-2009 08:56 PM
Belly pan wraps over side, can I put it under? bmklawt Belly Pans & Banana Wraps 3 02-03-2009 06:33 AM
