Old 07-30-2023, 09:57 AM   #1
1990 34' Excella
Goodeve , SK
Replacing Entire Bellypan, What to Use?
Hi there, I'm restoring a 1990 Excella.
Could someone confirm/deny that this will work for my bellypan? It's AS052 5052-H32 Aluminum Sheet 0.032in. Or does anyone have recommendations for what to use.
https://millenniumalloys.ca/product/...ize=Full+Sheet
Zoe Unruh is offline   Reply With Quote
Old 07-30-2023, 10:46 AM   #2
1966 22' Safari
Fredericksburg , Texas
Iím sure others will offer their opinions. 5052 H32 is a popular choice. It is strong, good corrosion resistance and has great workability. I think itís a good choice for the belly pan. Use the old belly pan as a pattern if itís useable. Good luck
Bubba L is online now   Reply With Quote
Old 07-30-2023, 10:57 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
5052 will work fine. I think I used 6061 T6, and it was really tough to bend to make the wraps along the sides. I used 5052 for the interior and was easier to work (plus it was cheaper then the 6061).
good luck
Old 07-30-2023, 12:42 PM   #4
1990 34' Excella
Goodeve , SK
Thank you! Relieved this step isn't going to entirely break the bank (for a change haha).
Old 07-30-2023, 02:16 PM   #5
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Good information, I need to replace my belly pan at some point.
10Smiles is offline   Reply With Quote
Old 07-30-2023, 05:16 PM   #6
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
One piece belly pan
I went to a semi trailer manufacturer (I believe it was Utility) to purchase my aluminum for my belly pan. I myself didn't care what kind of aluminum it was. Good enough for semi trailer roofs, good enough for a belly pan. I got it all in a roll and installed it as one piece. Still looks great after 15+ years. No sagging, rips or cracks. I did my belly pan by myself but for that large of a trailer you might want some help.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-30-2023, 05:55 PM   #7
dznf0g's Avatar
Oswego , Illinois
So, I'm getting a lot of miles logged, and imo, if I were replacing the belly sheet, I'd go with some thicker material. Every year I find the sheet has worn completely through the rivet heads from "flapping in the breeze"
I keep patching in an 1"square "buffer" plate when replacing the large head rivets. Click image for larger version
Sent from my SM-S901U using Airstream Forums mobile app
-Rich-
Old 07-30-2023, 06:10 PM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I used .040 5052-H32. It's my opinion that the thicker is easier to use than the .032. I installed it in multiple sections because it's easier, especially for access to tanks, valves etc. My pans are installed with aircraft nutplates so removal and installing the pans only takes a few minutes. But aircraft structures is my background so I'm not the norm.
Replacing fan and vent plastic rather then entire vent estock Roof Vents, Skylights & Fans 2 08-08-2019 09:55 AM
entire 1991 airstream 34' excella the entire trailer all parts EVERYTHING woodmon8 Airstream Classifieds 1 03-13-2015 12:45 PM
BellyPan and Wheel Well Caulking/Sealer mbatm01 Belly Pans & Banana Wraps 2 09-07-2004 06:19 PM
Water in Bellypan? Waterman Belly Pans & Banana Wraps 6 12-07-2003 09:41 PM
Bellypan Rivet Question Creampuff Our Community 7 01-22-2003 06:42 PM
