Old 02-15-2022, 10:29 AM   #1
1984 31' Excella
Fitchburg , WI
Replacing Belly Pan, but not with Aluminum ???
Hello Friends, I would like to replace our belly pan. They're not in great shape. I would like to have future access for any service or modifications. Has anyone replaced the aluminum with something like corrugated plastic sheet? Maybe more smaller pieces and, used screws rather that rivets? If so,
What material was used? Where did you get it?
Thanks for your feedback, Bill
Bill Dietlin is offline   Reply With Quote
Old 02-15-2022, 11:54 AM   #2
1979 31' Excella 500
Desert , California
That is my plan, using smaller stiffer aluminum plates that will be screwed in. However, I have not reach that step in my rebuild yet
Sylvain is offline   Reply With Quote
Old 02-15-2022, 12:46 PM   #3
DonRich7878's Avatar
2013 30' Classic
Key West , Florida
There are a number of thin light weight materials that will work, some of which can be purchased at your local hardware store. Most of these products will be in 4x8 sheets. I would also check in with a local metal fabrication company for additional options and installation ideas.
DonRich7878 is offline   Reply With Quote
Old 03-19-2022, 11:53 AM   #4
1984 31' Excella
Fitchburg , WI
So I purchased ten 4 x 8 sheets of black 1/4" corrugated plastic sheets from Polymershapes in Naperville, IL. I have a while before I install them because other work that I want to accomplish before I get to that step. I will update things when I have something to show.
Tuck the side belly wrap under the flat belly pan or the other way around? haaseome Belly Pans & Banana Wraps 4 08-24-2021 11:34 AM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Replacing my belly pan and drilled through my black water tank bwilson1 Airstream Trailer Forums 17 08-23-2014 09:14 AM
Replacing under covering - Belly Pan glarue Belly Pans & Banana Wraps 10 02-14-2014 02:49 PM
Replacing belly pan on '61 Avion - Advice needed Smoky Belly Pans & Banana Wraps 13 09-24-2012 11:51 AM
