Old 10-22-2016, 07:13 PM   #1
1973 29' Ambassador
Haughton , Louisiana
Removing the belly pan
Need help!! How hard is it to remove the belly pan and reinstall if its in good condition and what tools and supplies should i gather for the job including the reinstall? I have a 1973 29' Ambassador that i just bought and i really need to do a rear frame inspection. Any help would be much appreciated.Thx
captlou is offline   Reply With Quote
Old 10-22-2016, 08:01 PM   #2
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
I'm not sure on a 73, but the flat metal under the belly should unrivet, just drill out the pop rivets with the appropriate drill bit. With in-belly tanks be really careful where you drill and how deep. Biggest worry to me is what is in the belly pan. I've never opened up a belly pan that wasn't full of dirt, mouse droppings, and who knows what else, and if you remove it be prepared for what will come out.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 10-22-2016, 09:23 PM   #3
1973 23' Safari
1970 27' Overlander
Boerne , Texas
An 1/8 drill bit will work for.some. a cold chisel and hammer works real well, but you will widen some holes. VTS sells rivets for reinstalling belly pan that have a broad head for beter holding.. Do wear eye protection and some type of mask to prevent inhalation of dust and other nasty stuff.
Greg
Greg1410 is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Removing Rear Belly Pan kneal Belly Pans & Banana Wraps 3 02-13-2007 09:00 AM
Removing the belly pan Flyboy Belly Pans & Banana Wraps 9 11-15-2005 08:11 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 12:17 PM
