Old 03-29-2023, 07:10 PM   #1
2000 25' Safari
Calgary , Alberta
Remove black cover
Hi
Hopefully not a totally stupid question.
How do I remove the black cover marked in the photo?
Gunnar
groetschel is offline   Reply With Quote
Old 03-29-2023, 07:18 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I would say that you will have to remove the "beltline" or "rubrail" or whatever it is called--the piece of trim that covers the line of rivets that connect that black plastic to the exterior skin of the trailer.
Old 03-29-2023, 08:53 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Why are you needing to remove that panel? If it's to get to something under the trailer it's common to remove the flat belly pan, not the curved section. What's your end goal?
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 03-29-2023, 09:41 PM   #4
2000 25' Safari
Calgary , Alberta
I am afraid of removing the belly pan. I just wanted to get rid of a black water tank which is installed in the subfloor (maybe see my other post if possible).
Thanks for any suggestions.
Gunnar
Old 03-30-2023, 09:00 AM   #5
1994 25' Excella
The belly pan will be easier to remove than the curved sections, and if my trailer is anything like yours you are not going to get the tank out by removing only the side curved sections.
To remove the curved sections you've got to get the belt line trim out of the way to get to the rivets underneath. Someone who's done it on a trailer like yours will hopefully chime in and post some more specific information.
Richard
11018
Interior Finish? To remove or not to remove - can I use a heat gun stormbornSG Interior Restoration Forum 4 02-08-2017 03:31 PM
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 01:57 PM
How to remove door to remove frig Silver84 Refrigerators 6 07-06-2015 01:32 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
How to remove the antenna cover... Skamper1 Audio, Video & TV 0 03-18-2010 02:54 PM
